Glad to hear you are sorted and that my notes were of help.
I have a shortened 3mm A/F Allen Key, (that is, shortened on the short arm of the Allen Key), which is handy for this type of job. While they can be shortened on a grinder. There is a risk of softening the Allen Key, without liberal quenching. I normally use a manual Ceramic Tile cutting saw and just clean up the cut on the grinder afterwards.
Keep the cut-off piece as this can be used at a later date for an extended Allen Key, for those hard to reach capscrews. If it is fitted into the end of a piece of Hexagonal mild steel bar, a socket wrench or spanner can be used to apply the turning motion.
Gray,
