English dialect
English dialect
Home › Forums › The Tea Room › English dialect
Viewing 25 posts - 1 through 25 (of 179 total)
  • #316834
    Roderick Jenkins
      @roderickjenkins93242
      This is way, way off topic. Over on another forum one of the members used the phrase " on the scunt" to mean crooked or out of alignment. The only other person I've heard use this phrase is my wife and she picked it up from a work colleague some years ago. Google only seems to recognise meanings for scunt that are, shall we say, unhelpful. However, the origin for the alignement meaning seems to be from the Midlands. Any body else recognise it?
      Cheers,
      Rod
      #35006
      Roderick Jenkins
        #316835
        Brian G
          @briang
          I recognise that one despite coming from Kent – I guess it comes from working with a 70-year old Brummie engineer for many years. He had almost gone metric, replacing "a couple of thou" with "a gnat's cock" and referred to any machine that broke down often as "up and down like Collins's cocks" which I took to be a reference to the famous galloper.
          #316836
          charadam
            @charadam
            Is scunt not derived from squint?
            #316839
            Chris Evans 6
              @chrisevans6
              Although born in Worcestershire I consider myself a Brummie having lived and worked in and around Brum all my life. The on the scunt expression is from the Black Country along with many other shall we say "choice" expressions.
              #316840
                Conspicuous by its absence here Rod
                http://www.sedgleymanor.com/dictionaries/dialect.html
                … and it's not one I remember from my youth.
                Astonishingly, however, it is the second entry here:
                http://www.urbandictionary.com/tags.php?tag=sloping
                Edited By Michael Gilligan on 13/09/2017 16:28:47
                #316842
                Andrew Tinsley
                  @andrewtinsley63637
                  I originally came from the Black Country and have never heard that expression before. If it were a common word, I certainly would have!
                  Andrew.
                  #316862
                  Mick B1
                    @mickb1
                    Posted by Brian G on 13/09/2017 16:00:38:
                    He had almost gone metric, replacing "a couple of thou" with "a gnat's cock" …
                    I worked in a number of engineering shops around Nottingham in the 70s. I found I could gain a good idea of the normal standard of precision in each by asking how big a gnat's cock was in their shop. A couple of thou meant quite a good outfit. Fifteen thou meant worn machinery and rough work.
                    #316865
                    Nick_G
                      @nick_g
                      English dialect can be very confusing to some not from a particular area or country.
                      e.g. the expression "The dogs bo11ocks"
                      "You have made a right dogs bo11ocks of that" generally means you have made a mess of it.
                      But said with a different tone of voice, expression and smile "That's the dogs bo11oks mate" would mean that it was very good and a compliment was being paid.
                      Same expression but different delivery means two totally different things. Perhaps it's just a north west / Warrington thing.!
                      This is why internet forums, text messages and places like facebook a reader can get the wrong impression of what the poster meant as there is no tone of voice, facial expression and regional differences often taken into account.
                      Nick
                      #316869
                      Fowlers Fury
                        @fowlersfury
                        "I worked in a number of engineering shops around Nottingham in the 70s. I found I could gain a good idea of the normal standard of precision in each by asking how big a gnat's cock was in their shop"
                        Originating from that same city as Mick B1 worked in; the unit of precision I most encountered but frequently couldn't work to was a gnat's cock hair !
                        #316888
                        Jeff Dayman
                          @jeffdayman43397
                          "smaller than the hair on a gnat's a$$h^le" was one common expression in shops I worked in.
                          "smaller than a gnat's eyelash" was another more polite one.
                          #316891
                          larry Phelan
                            @larryphelan54019
                            Perhaps I should replace my micrometer ?
                            #316901
                            Fowlers Fury
                              @fowlersfury
                              Some more precise definition of dimensions seems necessary here !
                              It would appear that the only published measurement is that the common adult gnat is (quote) "~6-7mm” in length.
                              If we (very) generously assumed that the male’s member was 10% of its body length then the unit of a “gnat’s cock” is a rather coarse 0.6mm or 0.026 inch. So perhaps not very demanding in terms of precision working after all?
                              However, the diameter of a single hair on that appendage is unlikely to represent more than say 1/100th of the appendage’s o/a length. Here then we encounter a much tighter standard of precision working i.e. 0.00026 inch.
                              Even given the gross estimates in the above derivations, I rather think engineering to a GCH, rather than to units of GCs represents a much better standard of workmanship.
                              #316905
                              Meunier
                                @meunier
                                Posted by larry Phelan on 13/09/2017 19:46:16:
                                And which part of a gnat's anatomy would you choose to replace it with, Larry ?
                                DaveD
                                #316906
                                Brian G
                                  @briang
                                  This is reminding me of a story told by a colleague who was in the far East during the war. The close up pictures of mosquitoes in the film show given before shipping out had nothing to indicate scale. As a result he and his comrades just brushed 'gnats' aside whilst on the lookout for mosquitoes the size of dragonflies.
                                  #316908
                                  Harry Wilkes
                                    @harrywilkes58467
                                    Posted by Andrew Tinsley on 13/09/2017 16:23:53:
                                    Andrew.
                                    Hi Andrew I to come from the Black Country and in my working environment the term was used a lot so maybe it was down to where one worked !
                                    H
                                    #316909
                                    Robert Dodds
                                      @robertdodds43397
                                      As a North Midlander I recognise the "skunt" as a term for skewness but I also have come across those from Rose country who might refer to "Not wreck t' th ay"
                                      In terms of scale, which is the greater, a gnats cock or a smidgin?
                                      Can anyone elaborate on the difference between a Timper and a Spelcher?
                                      I know that if it only a smidgeon out you can put it right with a Timper but big ones need a Spelcher to shift them
                                      In the more refined Enginnering Shops the faulty part might be known as a cobble or clanger and finish up being "chucked on the shawd ruck" along with any other dingers.
                                      Up and down the country there are many different dialects and workshops within each. They pick up words that associate with the particular industry or craft of the area and are meaningful there.
                                      Its what makes the English language so colourful. Long may it last!
                                      Bob D
                                      #316910
                                      norman valentine
                                        @normanvalentine78682
                                        Could it be a derivation of the word cant as used in shipbuilding to describe an angled frame?
                                        #316911
                                        Mark Rand
                                          @markrand96270
                                          I can't work to the precision achieved by some of our members. I only work to the nearest RCH…
                                          #316914
                                          Chris Gunn
                                            @chrisgunn36534
                                            I have often heard the term used and I am in the midlands. For example when installing machinery, if the machine was installed "on the squint", it needed "scunting" over a bit to get it in the right position.
                                            Chris Gunn
                                            #316924
                                            Bill Pudney
                                              @billpudney37759
                                              Another one is "snape". Where I did my apprenticeship, on the Isle of Wight, I learn't that a "snape" was a chamfer at something other than 45 degrees, for instance 30 degrees.
                                              Some years ago, in Australia, I put snape with dimensions on a drawing. When the drawing hit the workshop, the laughter could be heard back in the DO. Has anyone else heard of "snape", or was I sold a typical wind up the apprentice line??
                                              cheers
                                              Bill
                                              #316928
                                              GoCreate
                                                @gocreate
                                                As a Northumbrian a part that is within a Midgy's nif naf is good enough most of the time.
                                                #316939
                                                Martin Kyte
                                                  @martinkyte99762
                                                  The inspection department wish to know which species of gnat ?
                                                  Martin
                                                  #316960
                                                  Fowlers Fury
                                                    @fowlersfury
                                                    "The inspection department wish to know which species of gnat ?"
                                                    How typical of 'em sad
                                                    Perhaps you could refer the department to that incontrovertible source of all wisdom – Wikipedia – which states "Gnat is a loose descriptive category rather than a phylogenetic or other technical term, so there is no scientific consensus on what constitutes a gnat."
                                                    The corollary of which, one must presume, is that there is no scientific consensus of what constitutes a gnat's cock.
                                                    Ah well, back to the calipers and slide rule…………………
                                                    #316961
                                                      smiley
