end mill speeds
end mill speeds
Home › Forums › Beginners questions › end mill speeds
  • #148450
    Eric Cox
      @ericcox50497
      .Have been trying to calculate end mill speeds. I've found two formulas on t'internet.
      1) SFM*3.82 / Dia
      2)SFM*12 + Dia * 3.142
      which is correct
      #7096
      Eric Cox
        @ericcox50497
        #148451
        kevin grieve
          @kevingrieve63008
          not sure which is correct but this guy has a real simple way to calculate speeds on his web site,as well as other tutorials.
          http://www.tomstechniques.com
          hope this helps.
          #148452
          David Jupp
            @davidjupp51506
            Looks like they started out the same, but have been copied incorrectly at some point
            2) ought to be (SFM*12)/(Dia*3.142) which is equal to 1}
            #148458
            Gary Wooding
              @garywooding25363
              You might find this useful. There is also an Android version.
              John Haine
                @johnhaine32865
                Gary, that looks brilliant. Just downloaded to my iPad, seems to work very well.
                John.
                #148469
                stevetee
                  @stevetee
                  12 S
                  Pi D"
                  Always worked for me. The cutting speed in feet per minute would be 40 for cast iron and 70 for steel
                  So for a 2 inch cutter on steel
                  12 x 70 =840
                  3.14 x 2= 6.28
                  =133 and a lot of decimal points
                  Back in the real world somewhere between
                  about 110 and 140 rpm would do nicely.
                  Multiply speed in feet by 12 ( to covert to inches) divide by the circumference of the cutter gives you the revs that give you the cutting speed in inches per minute
                  #148487
                  websnail
                    @websnail
                    Never worked it out in my life, always worked by feel.
                    That's the beauty of manual machines smiley
                    #148494
                    Rik Shaw
                      @rikshaw
                      Websnail – agreed – nothing quite like a little tactile feedback – if it doesn't like it then it will tell you – simples!
                      Rik
                      #148517
                      jason udall
                        @jasonudall57142
                        Too lazy this morning..how far out would 10, 000 rpm /dia (mm) be?
                        #148518
                        jason udall
                          @jasonudall57142
                          Lets try…say 70 feet/min
                          2″ cutter
                          Above we get 133 rpm.
                          10 ,000/(50.8)= 196 rpm
                          Working through from70 f p m would give 6790 /dia
                          In any case there is a constant that from taste/experience gives a finish you desire and once established a simple divide by cutter diameter will yield an rpm you probably don’t have anyway…
                          Don’t get hung up on number of flutes…that only effects depth of cut not spindle speed
                          #148523
                          MadMike
                            @madmike
                            "Don't get hung up on number of flutes"????
                            That's not strictly true when using end mills or other multi tooth cutters. The feed in feet/inches/metres etc per minute equals the feed per tooth per revolution multiplied by the number of teeth. So the speed of spindle needs to be such that you can achieve the feed rate which is both safe and efficient.
                            Steve 40 fpm for cast iron, and 70fpm for mild steel is very low even for HSS tooling. For example cast iron should be roughed at around 170fpm and finished at around 250fpm. Mild steel at 100 and 150fpm respectively.
                            Carbide tipped tooling substantially increases all of the above such as 200 to 350 surface feet per minute.
                            Of course all of the above assumes machinery in good condition, tools ground correctly, machinery with sufficient rigidity to allow the speeds refered to.
                            #148528
                            jason udall
                              @jasonudall57142
                              Mike.. I was referring to the Surface speed..yes in feed rate and depth of cut are effected by tooth count.
                              And yes 70 fpm is probably very conservative. .
                              #148546
                              colin hawes
                                @colinhawes85982
                                I reckon 500 RPM for a 1/2 " dia HSS cutter on mild steel and other sizes approx. proportional ; ie 1000 RPM for a 1/4" dia cutter.
                                #148548
                                Bazyle
                                  @bazyle
                                  For amateurs spinning too fast means feeding impossibly fast to avoid rubbing and hence overheating. Better to work out how fast you want to turn the handle and work back to a minimum 1 thou feed per tooth cut.
                                  For industrial use with cooling the target speed is the speed of sound in the material – so around 250fpm.
                                  #148552
                                  Anonymous
                                    Posted by Bazyle on 31/03/2014 17:33:28:
                                    Never heard that one before! The speed of sound in cast iron is more like 10000 feet per second, although it varies widely according to the precise mode.
                                    #148573
                                    Roy M
                                      @roym
                                      Eric,
                                      It's easier in metric.
                                      start from the recommended surface speed.
                                      r.p.m (n) = Vc (given surface speed in metres/min) x 1000 then divide all that by the circumference of the cutter (Pi x D )
                                      Grey cast iron 18-25 m/min. Fz (feed/tooth) ; dia 6mm .02mm. dia 20mm .071mm.
                                      dia 50mm .13mm. These feeds are for a full width slot (Ae=1)depth equal to half the cutter dia,(Ap=0.5)
                                      Feeds are adjusted depending on depth (Ap) and width (Ae) of cut.
                                      Roy
                                      #148575
                                      Bazyle
                                        @bazyle
                                        Andrew, I just looked up on the web and a couple of sources gave the speed in 'iron' as 5100m/s so roughly 250fpm.
                                        At the atomic level nothing cuts, a tool just forces cracks to open. Cracks propagate at the speed of sound. Hence the most efficient way to 'cut' is to follow along as the crack opens up.
                                        #148577
                                        Les Jones 1
                                          @lesjones1
                                          Hi Bazyle,
                                          I don't understand your maths.
                                          5100 m/s = 5100 * 60 meters per minute = 306000 meters per minute
                                          306000 meters per minute = 306000 * 1000 (to mm) /25.4 = 12047244 inches per minute
                                          = 12047244/12 feet per minute = 1003937 feet per minute
                                          I can not see how you get 250 feet per minute.
                                          Your value for the speed of sound in iron works out to 16983 feet per second to put it in the same units that Andrew used.
                                          Les.
                                          Edited By Les Jones 1 on 31/03/2014 23:09:11
                                          #148581
                                          MICHAEL WILLIAMS
                                            @michaelwilliams41215
                                            A crack in metal can propagate at any speed from zero speed to creep speed to very fast indeed .
                                            What happens in any particular case depends on a very large number of factors including probability .
                                            Most real mechanical objects failing by rapid crack propagation do so in times of order milliseconds to seconds .
                                            More common though is failure by creep speed crack propagation – sometimes takes years for components to fail .
                                            Fascinating subject and much more to it .
                                            Michael Williams .
