Emma Victoria – small drawing error
Home › Forums › Locomotives › Emma Victoria – small drawing error
  • #132542
    David Milway
      @davidmilway25658
      I have noticed a small discrepancy between the Drop Arm and the Crosshead.
      The Drop Arm, ME4459 page 50, shows 3 holes of No 34, a 6BA clearance.
      The Crosshead. ME4465 page 459, shows 2 8BA along the bottom edge.
      The extra hole is a simple addition but the hole size might catch someone out.
      David Milway
        @davidmilway25658
        Small drawing error identified
        #134361
        Henry Wood
          @henrywood50588
          Hi David
          Thank you for pointing out the hole size error on the drop arm for Emma-Victoria, these should be No.44 not No.34, a close fit for 8 BA fixings as indicated in the write up. The third hole as you say being an extra fixing point at assy. with the crosshead.
          Henry
          #144523
          Chris Parsons
            @chrisparsons64193
            Been looking at the "Emma Victoria" as a first loco, and not being a ME subscriber I wonder how many back issues I would have to buy to get the complete series? Anyone know when the first one came out?
            It looks like the 30 November 2012?
            Chris
            #144524
              4475 has the 16th part and its not finished yet. May be easier to take out a Digital or Print Plus Subscription and be able to view the series here.
              J
              #144546
              Chris Parsons
                @chrisparsons64193
                Blimey – didn't realise it was such a long series of articles, think the digital subscription idea is a good one, thanks
                I'll have to check to make sure I can get a subscription that starts with the first one (I have read some of the horror stories about the MTM subscription policies…)
                Chris
                #145024
                Chris Parsons
                  @chrisparsons64193
                  I have now looked into the digital subscription details – and it appears that if I subscribe, and get (for instance) the first issue the series appears in – 4444 – I will only be able to continue to see this issue if I continue to renew my digital subscription every year??
                  I seem to remember reading something about this (the horror stories I mentioned) is this actually the case still?
                  I know you can keep the downloaded digital subscriptions but these start from the date you subscribe – it doesn't seem I can ask for them to start at issue 4444?
                  Chris
                  #145049
                  Steambuff
                    @steambuff
                    Chris,
                    You are correct
                    The issues that you download through Pocketmags start with the issue that is published after your registration.
                    Access to the online-archive is only possible if you have a valid digital subscription.
                  Home › Forums › Locomotives › Topics
