Drummond b lathe advice
Home › Forums › Workshop Tools and Tooling › Drummond b lathe advice
  • #504592
    Neil Mccarthy 1
      @neilmccarthy1
      I have bought a project Drummond b lathe and I was wondering if anyone has any pictures or advice to connect the motor to it. I know I will have to make a metal frame just after some guidance please if anyone can. I’m a long way off putting the motor on as I will be doing a full strip repaint and rebuild on this
      Thank you in advance
      https://ibb.co/VNjczZG
      https://ibb.co/whKY7Cq
      https://ibb.co/nMFJJ4M
      https://ibb.co/4KZLpzW
      #20003
      Neil Mccarthy 1
        @neilmccarthy1
        #504597
        David George 1
          @davidgeorge1
          Hi Neil the best way of driving these older lathes are with a intermediate shaft and two belts as the top speed is less than 1000 RPM as the bronze spindle bearings limit that. A motor was originally mounted on a cast iron base sometimes with a treadle and gear. I have an M Type and have a little handbook which I can email to you if you send me a message with that address if you want it as it has information on early models and can help with setup etc.
          David
          #504601
          Neil Mccarthy 1
            @neilmccarthy1
            Thank you I have sent you a message
