Dro for mill
Dro for mill
Home › Forums › General Questions › Dro for mill
Viewing 3 posts - 26 through 28 (of 28 total)
  • #357966
    I.M. OUTAHERE
      @i-m-outahere
      Posted by mgnbuk on 15/06/2018 16:03:09:
      Yes, the Y axis will be fitted to front of table
      The table (left – right movement when stood in front of the machine) is normally the X axis – the Y axis is the underslide "in – out" movement.
      Nigel B
      The way i explian it to newcomers ( on a mill ) is the x axis is across , it looks like a cross ( X) and travels across from left to right and vice versa when standin in front of the mill.
      The y axis travel is toward You and away from You so think of the word You which starts with Y so it is the y axis .
      #357988
        Confusing isn't it.
        When drawing a 2D graph youngsters are taught the mnemonic 'Y to the Sky', meaning Y is the axis running from top to bottom of the paper. Works on a vertical computer screen too; the Y axis runs from ceiling to floor. So far so good, but this isn't how dimensions run in 3D on Planet Earth!
        On machine tools, as is right and proper, x is right-left, y is forward back, and z is up-down.
        String theory suggests we live in an 10, 11 or 12 dimensional world. Just as well only 3 spatial dimensions matter to us – the thought of buying and fitting 11 DRO scales is just too painful!
        Andrew Tinsley
          @andrewtinsley63637
          Hello Dave,
          I would not worry about the effects of String Theory. In 40 odd years of development, it has not predicted a single thing that can be verified experimentally. The inference that any sane person would make, is that the theory is wrong.
          However it doesn't cost much to be a physicist who is involved in this folly, hence I suspect its popularity is largely down to needing only a small research grant! The King has no clothes comes to mind.
          Andrew.
