Drip oiler question
Drip oiler question
Home › Forums › Help and Assistance! (Offered or Wanted) › Drip oiler question
  • #32993
    Brainsparks30
      @brainsparks30
      #301479
      Brainsparks30
        @brainsparks30
        I need to fit a replacement drip oiler the the ML7. Its the right thread, but sits to high to screw down on its seal. Does that matter? It sits over the bearing its meant to lube, so surely its going to work?
        #301487
        Chris Gunn
          @chrisgunn36534
          Brainsparks, its going to work. You could make a small brass collar so the oiler seats down on that which would tidy the job up.
          Chris Gunn
          #301502
          Brainsparks30
            @brainsparks30
            Thank you, had to be sure. Made assumptions before, and they were not always right…
            #301510
            Tim Stevens
              @timstevens64731
              You can even move the oiler to a handier position (if needed) using a threaded adaptor and a length of plastic or rubber hose. On my Myford the oiler away from the chuck was too close to the belt drive gubbins, so I lifted it (as above) with two 1/8 BSP adaptors, and it works OK.
              But I still forget to turn it off …
              Cheers, Tim
