Drill sharpeners
Drill sharpeners
Home › Forums › Beginners questions › Drill sharpeners
Viewing 25 posts - 1 through 25 (of 37 total)
  • #452735
    Mark Gould 1
      @markgould1
      Gents,
      I have a lot to learn and it will be some time before even my questions make it out of the Beginners section, let alone my answers.
      So with this question: my father and I have a lot of drills. Some he has had for 50 years and I don’t want to replace them. I can take them to be sharpened but this in a pain in the ar$e. I have therefore been looking at a drill sharpener. Not the Drill Doctor ones but one step up from there. As with Chinese lathes etc. they come in a variety of packages and colours but are essentially the same machine. They have a lid on the front which contains a set of ER20 collets.
      Can anyone tell me if this is a wise buy? Or is the Drill Doctor just as good? I looked on youtube and I must admit the DD didn’t exactly inspire me with confidence.
      Thanks again all,
      Mark
      Edited By Mark Gould 1 on 17/02/2020 18:51:34
      #10082
      Mark Gould 1
        @markgould1
        All the same? Things to avoid?
        #452741
        David Noble
          @davidnoble71990
          Hello Mark, I'm a believer in 'the only way to learn is to have a go' With this in mind, I would suggest that you don't buy a drill sharpener but take the time to learn how to sharpen them freehand. I have never used a drill sharpener and have managed to drill lots of holes, some of them quite accurately!
          Hope this helps. David
          #452742
          Henry Brown
            @henrybrown95529
            There is a very extensive test of the Sealey one on here if you search…
            #452744
            Mick B1
              @mickb1
              If you can spare the time to put in the practice, study the angles given in various drawings of drill points, and think about creating those in a bench grinder.
              I don't remember exactly how long it took me, but I think I spent about a day or maybe two in 1975 learning to grind drills offhand, and I've never really taken drill sharpeners seriously since. It's not magic, it's just a matter of understanding the intersection of curved surfaces with time and practice. A sharp eye, maybe a lip angle gauge if you need one, and a good steel rule are enough for equalising the angle and length of cutting lips, and if the swarf curls back the same down both flutes you know you're pretty close.
              Put the work in, and a blunt – or even damaged – drill will never be much of an obstacle again.
              Ah, I see David N's been saying the same…
              Edited By Mick B1 on 17/02/2020 19:24:20
              #452752
              Mark Gould 1
                @markgould1
                Now thats encouragement! I will give it a go. I have a decent bench grinder with good stones so any failings are squarely on me
                Thanks,
                Mark
                #452757
                JohnF
                  @johnf59703
                  Mark, you don't give any indication the size range of your drills but I agree with David and Mick above its not rocket science and you can learn with a little practice to sharpen drills very effectively on and off hand grinder. If you are close enough to me – nothing on your profile ! – I would be happy to assist – I am in NW Lancashire.
                  I do have a machine recently re-furbished to sharpen small drills I now find difficult due to ageing eyesight ! However I used such a machine when in industry for small drills, it will handle down to No 60 or 0.5mm and up to 1/4" Look at Christen in my albums to see the machine.
                  Also if you put "Drill sharpen" in the forum search there is a plethora of posts — note sharpen not sharpener, sharpening !
                  John Baron
                    @johnbaron31275
                    Hi Mark, Guys,
                    If as you say, you have a decent bench grinder, then make up some simple jigs to help you with the angles. Which is what I used to do, until I made the four facet drill grinder by John Moran at "GadgetBuilder.com" !
                    #452759
                    Andrew Tinsley
                      @andrewtinsley63637
                      The best cheap drill sharpener I have used is a nasty plastic thing called a Plasplugs sharpener. Don't know if they are still available, but with a little care they can produce much better results than most people can achieve offhand. There are some people that can get very good results by offhand grinding. My late father was one such, but I have NOT inherited that particular skill!
                      Andrew.
                      #452766
                      Martin Thomson
                        @martinthomson36607
                        I grind drills in four ways:
                        Most common would be using my drill doctor drill grinder. I bought one a few years ago on offer for about £30 and actually it works so well, if the drill fits I grind it that way. The only downside is it doesn't do a split point grind. It wins because it's sooo easy. There are a lot of drill doctor clones now, like the one from sealey, which are probablt fine as well.
                        Second most common would be just grinding by hand. About 45 years ago my dad taught me how to grind a drill bit. Maybe 30 minutes of 'like this' no, left a bit, right a bit, straighter, bit higher on the wheel, etc, etc. You can't beat hands on training from someone that knew what they were doing. That was followed by being handed a big box of blunt drills, and a lot of practice. Hand ground drills are rarely perfect but with enough practice are good enough for most purposes, and it takes seconds.
                        Third would be a proper split point grind which I do with my own custom grinding setup which is a hybrid from eccentric engineering's plans and Harrold Hall's book. TBH, it is such a faff to setup I rarely bother. As a result I have about 20 5mm drills that get a proper split point grind. I generally start all larger drills at 5mm and work my way through the box full until they're all blunt. Then I setup and grind them all at once.
                        Finally, very small drills get shaped by hand with a stone. I can put a split point on small drills by hand in a couple of minutes. It is simply a matter of filing two flats that meet at the center at about 15 degrees, then another two a little further out and rotated slightly, at about 5 degrees. Again, it's just a matter of practice.
                        #452774
                        Mark Gould 1
                          @markgould1
                          JohnF,
                          I am in the Netherlands so that won't work but many thanks for the offer. I have just been looking on youtube (where I learn most things these days) and will tackle a drill or two next week when I have some time. The range of the drills I want to keep is probably from 8mm up to 12mm.
                          I'll look at the gadgetbuilder.com site, thanks John Baron and the others who have chimed in. Much appreciated.
                          Mark
                          #452782
                          peak4
                            @peak4
                            Posted by Mark Gould 1 on 17/02/2020 21:09:37
                            ……………………… The range of the drills I want to keep is probably from 8mm up to 12mm.
                            Mark
                            .Mark, 8-12mm are in the fairly easy range to sharpen, not too fiddly and not needing a large specialist grinder.
                            Here's a post I put up a while ago, which also provides a link to the Sealey posting.
                            If I need a quick sharpen I often use the Sealey as it's on the shelf ready to go with no setup time.
                            My preferred jig is the Reliance, but when the length of a Morse drill gets too short, one can't pre-set the correct overhang as the morse taper interferes with the jig.
                            The genuine Picador works well, though less so with morse drills as the tapered end doesn't sit well in that end of the jig.
                            I've a modified Picador lookalike, which, rather than having a grove to locate the dead end of the drill, has an adjustable height centre point, that way there's nothing to interfere with the tapered end.
                            My plan is to make a better engineered adjustable centre height end for the genuine Picador, then I should have the best of both worlds for short taper ended drills.
                            I also have a genuine Potts, but really can't get the hang of the correct shape for the detent.
                            Bill
                            Edited By peak4 on 17/02/2020 22:00:56
                            #452787
                            Clive Foster
                              @clivefoster55965
                              Mark
                              I presume you were thinking in terms of something like this :– **LINK** . Fairly expensive but Cutwel are suppliers to the professional engineering trade so I'd expect that their version works properly and that they can provide support.
                              Looks like "same" thing is £100 or so cheaper direct from China but what the relative quality is like I don't know. Various other badges too at a range of prices.
                              Personally I prefer the type of sharpener that works out in the open so if things don't go to plan I can see what's going on and, hopefully figure out whats wrong. I rather like the looks of the Kaindl BSG20/2 **LINK** but suspect its quite costly.
                              If a four facet grind will do then the Tormek dbs22 **LINK** looks as if it should do the deed.
                              Agree with Andrew that the nasty little plastic device in the original PlasPlugs multi-sharp set up works unreasonably well. I have a feeling that their current version is different and not so good. Its been copied by several makers. Some got the geometry wrong and don't work. Probably by being too cheap.
                              The Scheppach version a bit more expensive than most but looks quite well made and has the advantage of handing drills up to 10 mm diameter **LINK** . The original Plasplugs device and most of the clones only go up to 5 mm.
                              When it comes to the inexpensive end of the market the great thing about the PlasPlugs and derivatives is that they have a built in jig to set protrusion correctly and a flip over drill holder pretty much ensuring the drill will be ground centrally. The inexpensive Picador, General, Spiralux et al swing across the side of the wheel jigs work very well indeed when set correctly. However no setting jigs are supplied, also the drill has to be removed from the holder and flipped over to do the second edge, so getting things right can be something of an art. It doesn't help that many imported copies are made with incorrect geometry so they can never work.
                              Grinding by hand is fine if you do enough to keep in practice. Its not too difficult to touch up a drill but keeping the point central over successive sharpenings is a whole n'other thing. Having got the drill sharpening gizmo for my Clarkson Tool and Cutter Grinder up and running I'm steadily working my way through my (mostly) ex-toolroom collection. I'm surprised how far out the hand sharpened ones are. They look OK and the sharp ones still cut well but the professional quality Clarkson device mercilessly exposes the errors.
                              #452789
                              Clive Foster
                                @clivefoster55965
                                Further to what Bill (peak4) says in the post above my previous one I've long felt that mating a version of the PlasPlugs / Scheppach et al flip over drill carrier and projection setting jig would properly sort the major issues with the simple swing across the side of the wheel sharpeners. Add a screw feed base to set cut and use a cup wheel for something even better.
                                Or mount it sideways, Kaindl style, and use the wheel periphery.
                                #452805
                                duncan webster 1
                                  @duncanwebster1
                                  Get hold of a bigish drill, say 20mm and with the grinder switched off get the feel of rolling the end of the drill against the wheel. Then scribe a line on your workrest to line the drill up against and give it a go. Nothing to lose.
                                  Edited By duncan webster on 18/02/2020 03:46:50
                                  #452808
                                  Mark Gould 1
                                    @markgould1
                                    Bill, I've seen a couple of the Picador attachments on Ebay recently. Perhaps worth a go. Thanks for the info. I will try free handing first.
                                    Clive, yes similar to that first one you posted. A lot of variations on a common theme. That Kaindl looks nice too but is probably eye watering expensive. The Scheppach (sounds German but isn't) one looks to similar but them a lot cheaper. I have a Scheppach 1 inch belt sander which despite its price has done a lot of good work so far. Your Clarkson sounds like the business I will dream on!
                                    Duncan, yes, thats the plan for the moment. Thanks, scribing a line is a good idea.
                                    Mark
                                    #452814
                                    thaiguzzi
                                      @thaiguzzi
                                      I get on well with the Picador Jig types. Clones can be made to work well with a bit of work.
                                      #452817
                                      IanT
                                        @iant
                                        I was recently given a large number of good quality (mostly Dormer) drill bits – unfortunately nearly all of them have been sharpened "off-hand" and frankly are currently useless – at least for drilling their nominal size.
                                        I use a Picador at the moment but four-facet seems the way to go on the larger sizes – still on the TUIT list though….
                                        IanT
                                        #452819
                                        not done it yet
                                          @notdoneityet
                                          I sharpen my drills off-hand. I don’t even expect them to be a precise size. Tiny ones are often dumped because they break – I don’t buy the cheapest tat – but all I expect of my large ones is that they cut fairly evenly from both flutes.
                                          We learned from an early age how to ‘tickle up’ a drill using the the two foot (or more) water cooled foot operated grindstone on the farm.
                                          Slow and not particularly aggressive but we knew when we got it right as we were only allowed to use the large hand operated breast-drill until the single speed black & Decker (600 rpm) came along. Nothing at all like precision work, for us, back then. It was the same with mowing machine knives – Dad’s resharpening lasted much longer than our first attempts…..
                                          #452821
                                          Mick B1
                                            @mickb1
                                            Posted by IanT on 18/02/2020 08:44:38:
                                            IanT
                                            I think you missed out a word, before or after "sharpened". The word is "badly".
                                            #452824
                                            BOB BLACKSHAW 1
                                              @bobblackshaw1
                                              In the late 70s the precision sheet metal company I worked for called for drills to be sharpened at various angles for different materials and the drill was checked by inspection on the shadow graph. I got quite good at doing them up to 1/4 inch, larger where done by the cutter grinder, I've lost the skill now but still grind my drills by hand with good results.
                                              Bob
                                              #452827
                                              Mick B1
                                                @mickb1
                                                Posted by BOB BLACKSHAW on 18/02/2020 09:27:33:
                                                Bob
                                                In thin sections and sheet metal, especially where the breakout side of the hole needed to be burr-free, I found it paid to use a point angle more obtuse than the standard 118-120 degrees, hoping to get the whole diameter cutting and supported on the cylindrical land before point breakout. Whatever worked for brass seemed to work much the same for alli. Don't remember coming across sheet steel or tube much in that situation.
                                                #452837
                                                BOB BLACKSHAW 1
                                                  @bobblackshaw1
                                                  At the time a lot of work was other than sheet metal,but special rivets needed different angles for 18g ,16g and no burns on the back when drilled.
                                                  Bob
                                                  #452843
                                                  Peter G. Shaw
                                                    @peterg-shaw75338
                                                    I use a Spiralux drill sharpener. It can be abused, especially if I'm "messing about", shall we say, but with care it works well for drill bits between 3mm and 12mm, although to be fair, at 3mm, the drill bits are too small for the tool to handle them easily, whilst at 12mm, the drill bits are rather too long to be easily handled.
                                                    As a result, 3mm and below are scrapped, indeed I have taken to buying the smaller drills in multiples of 5 (Arc Euro Trade, I think). I don't use the larger drills all that much so the 12mm, or to be strictly accurate, 3/8" up to 1/2" are generally used as they come regardless of hole accuracy. (Usually they are either clearance holes, or preparatory before boring.)
                                                    The biggest problem I have is that I tend to leave drill bit sharpening until absolutely necessary, and then I have a good "set to" which means that the grinder, a 5"/125mm machine without any cooling, starts to overheat, consequently resharpening can take a long time due to having to wait for the grinder to cool down.
                                                    However, I am well pleased with my Spiralux, especially as it seems to incorporate all the necessary angles as have been explained before in this forum. (I have a suspicion that Graham Meek might have had a lot to say about this. My apologies to Graham if I'm wrong.)
                                                    Peter G. Shaw
                                                    #452850
                                                    Simon Barr
                                                      @simonbarr48213
                                                      This something I've recently tried to learn having failed in the past. After stumbling across a short YouTube video last week I've had some success with the technique shown in it. My cheap Aldi grinder has a tool rest I made myself and I've scribed a line so I can attempt to keep at the right angle. So far I've tried with a 10mm and an 8mm and both drills have come back to cutting decent holes. I figured larger sizes would be easier to start with. I appreciate he shows a very simple grind but I'm hoping if I can perfect it then I can try altering the technique to suit. Link below.
                                                      Sharpening video
