Drill Sharpener
Drill Sharpener
Home › Forums › General Questions › Drill Sharpener
  • #22942
    Smudge
      @smudge
      Which one to buy
      #135149
      Smudge
        @smudge
        Hi All.
        Which drill sharpener do you all recommend . The eyes are getting tried.
        I was looking at the "Drill Doctor" (but it is expensive)
        Your ideas would be welcome.
        Thanks Doug (Jersey)
        #135151
        dave greenham
          @davegreenham19379
          Hi Doug
          have a look at Harold Hall's design
          in the WP series
          Ian Welford
            @ianwelford58739
            I bought the drill doctor and am very impressed with it. Easy to use and does a good job.
            Import the wheels from the USA and save a fortune!
            Ian
            #135165
            SverreE
              @sverree
              A bought a Drill Doctor 750X directly from the US, cheaper, but have to use a 230/110V transformer, the US suppliers only had 110V versions.
              I have read about people who have problems using it, but there are nice instructional videos on Youtube. I find it very simple to use – I have perfect drills all the time!
              Sverre
              #135196
              Versaboss
                @versaboss
                A very good drill grinder is the Vertex (possibly available from other manufacturers also) But not exactly cheap, though,,,
                Vertex
                A good video how to:
                use it
                Greetings, Hansrudolf
                #135198
                John Rudd
                  @johnrudd16576
                  I bought the offering MachineMart sell only to find it ’ crap' ….it relies on the user being able to grind both faces equally…..Maybe that's just my inexperience but to pay that sort of cash I'd expect something better than just a off hand grinder
                  #135204
                  Anonymous
                    I don't bother to sharpen drills below about 10mm. As standard I use Dormer A002 four facet drills, which are coated. One can buy an awful lot of small drills for the cost of a decent drill sharpener. I haven't blunted any of my larger drills yet, but they're mainly used for removing metal prior to boring so I'd just grind them freehand as great accuracy is not required.
                    #135208
                    daveb
                      @daveb17630
                      I have a vintage Reliance jig. Looks similar to cheap Asian devices but cast iron instead of light alloy and well made. Used with bench grinder, does a nice job, drills look factory ground and cut like new. I believe these were sold up to the mid 70s, expensive too! They occasionally appear on market tool stools for a pound or two, well worth picking up if you see one. There are three different sizes, the No.1 is OK for our sizes (about the same as the Asian devices), the No.2 is big, the No.3 is huge.
                      Ian Welford
                        @ianwelford58739
                        I too thought that the drill doctor 750 was expensive and I could buy a lot of drills for that… BUT then I found I had to wait 3 days because I damaged the size I needed to use before tapping and all the stores were closed- bank holiday etc.
                        So I swallowed my pride and imported a 750 ! I have not regretted it, apart from when I sharpened a left hand drill that I'd left in the "to sharpen box" embarrassed.
                        Must get round to making a 4 facet drill sharpener ( D G Brown type) this year.
                        Ian
                        #135455
                        Smudge
                          @smudge
                          Hi Guys
                          Thanks very much for your input.
                          I am luck, my two sons are treating me to a Drill Doctor 750 for Christmas.
                          PS It is great to be able to read up and ask questions , and always get great answers.
                          Thanks Guys
