Drill press vice positioner
Home Forums Manual machine tools Drill press vice positioner
  • #232653
    Gray62
      @gray62
      I read an article sometime in the last couple of years that described a postioner/holding device for a drill press vice that allowed the vice to swing across the table. Despite several searches through indexes, google etc I cannot find this article. can anyone help, I'm sure I didn't imagine it
      Gray62
        @gray62
        #232658
        Vic
          @vic
          Was it something like this?
          Gray62
            @gray62
            Hi Vic, it was along those lines but a bit more 'comprehensive'. I'm sure it was an article in one of the ME publications
            #232660
              Yes recent ME had a sort of parallelogram arrangement
              #232661
              Frances IoM
                @francesiom58905
                ME #4517 + 4518 taming the drilling machine vice by j maurel
                I do wish the login process on this site was tamed – a right pain since Neil ‘fixed’ it
                #232662
                Gray62
                  @gray62
                  Frances, thank you, that's the one
                  #232757
                  John Reese
                    @johnreese12848
                    I have a copy of the Float Lock vise made by an old toolmaker. They are great, but heavy.
                    http://www.bing.com/images/search?q=float+lock+vice&qpvt=float+lock+vice&qpvt=float+lock+vice&FORM=IGRE
                    The jaws are stepped so it like having a set of built in parallels.
                    #232759
                    John McNamara
                      @johnmcnamara74883
                      My solution is two pieces of 25 x 12 x 130mm steel bar with threaded hole set in the centre of one end forming a lever nut, round of the sharp edges to protect your hands.
                      Half inch bolts and a washers set from underneath the table completes the vice clamps. No more looking for a clamp. For an application like this a Whitworth thread is stronger than M12. due to the coarser thread
                      I just loosen the clamp levers and vice and all drag the vice into position.
                      Much stronger than a G clamp and no spanner needed.
                      Only a few minutes to make. cost from the scrap bin….nil.
                      Edited By John McNamara on 01/04/2016 08:02:19
