I have some brand name HSS and carbide double ended cutters so "known good" ones can be got.
That said I shan't be getting more unless the price is silly low. In practice the major issue is protecting the second end from inadvertent damage during insertion, removal and storage. Sometime it's hard enough to concentrate on one sharp end let alone two. Its a question of odds really. I know you, like me, will be careful but given that, depending on what you do, a cutter may go in and out of its holder perhaps a hundred (or more) times before becoming unacceptably blunt there is plenty of opportunity for the silly slip-up.
Although considered old hat now I like the Clarkson screw in type purely because there is so much less opportunity for the "Ooops, naughty words" moment. When you are unscrewing a cutter that is all you are doing. None of this business of releasing a collet with one hand and catching the cutter with the other. Native R8 on my Bridgeport being a particular pain with one arm reaching well up to get a hand on the drawbar spanner and the other waist high (ish) to catch the cutter. Most especially if its a big shank pulled up tight with a second heave!
(5 years on the air drawbar kit is still in the box)
Edited By Clive Foster on 09/05/2019 12:28:36
