Dore Westbury Milling Machine
Home › Forums › General Questions › Dore Westbury Milling Machine
  • #129560
    Smudge
      @smudge
      Hi
      Can anyone help, i need to buy some replacement drive belts.
      It is an "O" drive belt.
      Thanks for your help
      Smudge
      #22827
      Smudge
        @smudge
        Drive Belt
        #129565
        NJH
          @njh
          Hi Smudge
          I don't know that you will get them but Tony, at Lathes.co.uk, does supply various belts and belting. See HERE
          A 'phone call to him would find out and, even if he doesn't have one suitable, he may well be able to point you in the right direction.
          Good Luck!
          Norman
          Edited By NJH on 13/09/2013 22:17:41
          #129569
          Smudge
            @smudge
            Thanks Norman
            #129585
            Brian Wood
              @brianwood45127
              Hello Smudge,
              I bought two recently froim http://www.motionco.co.uk
              They do mail order, in the diameter you need and I would recommend you order a size [which you specify] that is tight rather than "easy", they stretch quite a lot from new.
              Nest wishes Brian
              #129642
              Ian S C
                @iansc
                You could use heat fusable round plastic belting, its good, although the only machine I run with it is my Super Adept, it has two bits of 5 mm belt, one from motor to jack shaft, the other from jack shaft to the lathe.
                I do use 3 mm dia as drive belts on my Stirling Engines. Ian S C
                #129710
                Smudge
                  @smudge
                  Hi Guys
                  Thanks Brian & Ian
                  I should get sortted now
