do i need reverse
do i need reverse
Home Forums General Questions do i need reverse
Viewing 25 posts - 26 through 50 (of 96 total)
  • #186211
    Les Jones 1
      @lesjones1
      Hi Kevin,
      The reversing switch is faulty. Which two of the wires A, B, C, D were connected to the motor terminals ? The reason I want to know this is that the results from your tests to not seem to fit with the fact that the motor only ran when the switch was in the reverse position. I would like to understand this apparent discrepancy.
      Les.
      kevin large
        @kevinlarge76611
        Hi les the wires where a and d so it looks like a new switch can you tell what kind of switch to get ie rating etc I see several types on ebay as I doubt I will be able to get one from warco
        kevin
        #186218
        Nicholas Farr
          @nicholasfarr14254
          Hi Kevin, I've been suspecting your switch is faulty, because it looks as if the red wires on terminal 11 and the black one on terminal 2 have been rather hot, so its probably been overloaded at some point and burnt the other contacts, but I'm as confused as Les because you say that you have connections on A and B in both forward and reverse and no connections on any of the others, so it should run forwards in both forwards and reverse.
          Regards Nick.
          #186219
          kevin large
            @kevinlarge76611
            After les comment I looked again and noticed the bar going through the the switch wasn’t all the way through after pushing it in all the way this is what I found
            3 4 r
            5 6 f
            7 9 f
            9 10 r
            11 12 r
            r reverse
            f forward
            kevin
            #186222
            Les Jones 1
              @lesjones1
              Hi Kevin,
              Your post this morning explains the mystery of why the motor only ran in the reverse position of the switch. With your previous information that there was no connections to C and D the motor could not run at all. (As my initial theory as to why the motor only ran with the switch in the reverse position was correct.) Is the line "7 9 r" a typing error ?
              If the shaft through the switch is square it is possible the cams could be in the wrong position on the shaft after pulling it out.
              Les
              Edited By Les Jones 1 on 13/04/2015 09:02:15
              #186235
              kevin large
                @kevinlarge76611
                Yes sorry 7 8 f
                kevin
                #186237
                kevin large
                  @kevinlarge76611
                  And the shaft running through the switch is square
                  kevin
                  #186243
                  Les Jones 1
                    @lesjones1
                    Hi Kevin,
                    9 and 10 should show continuity in forward and reverse. They must have done when you tested the connecton from wire B and the live pin on the mains plug as you said B connected to live in forward and reverse. The back two cams seem to be in the correct positions on the shaft now but if now 9 and 10 only connect in reverse then the front cam may be wrong. Did you pull the shaft out far enough to disengage with the front cam ?
                    Les.
                    #186244
                    kevin large
                      @kevinlarge76611
                      Hi les quit possible
                      kevin
                      #186248
                      Les Jones 1
                        @lesjones1
                        Hi Kevin,
                        The contacts 1 & 2 and 9 & 10 are operated by the front cam. Create a table of these two sets of contacts for the three positions of the switch. This is for two reasons. 1 To confirm you have not made an error testing. 2 To try to work out how to get the front cam in the correct position on the shaft. Does the shaft rotate a full 360 Deg or just 180 Deg ?
                        Les.
                        #186261
                        kevin large
                          @kevinlarge76611
                          I will have a fiddle tonight and see if I can get 9 10 right and then test all again
                          kevin
                          #186293
                          kevin large
                            @kevinlarge76611
                            It must of been my error I have continuity on 9 10 r f
                            kevin
                            #186297
                            Les Jones 1
                              @lesjones1
                              Hi Kevin,
                              Now go back to the test to create a table of which of the mains plug pins each of the 4 wires show continuity to in the three positions of the switch. I suggest you copy and paste the sample table with the question marks that I posted and just edit in L, N or NC to replace the question marks
                              Les.
                              Edited By Les Jones 1 on 13/04/2015 17:16:17
                              #186305
                              kevin large
                                @kevinlarge76611
                                Hi led
                                Forward
                                A. N
                                B. L
                                C. L
                                D. N
                                Reverse
                                A. N
                                B. L
                                C. N
                                D. L
                                Middle All no connection
                                Kevin
                                #186315
                                Les Jones 1
                                  @lesjones1
                                  Hi Kevin,
                                  That is all correct now. First confirm that I have read the coding on the motor terminals correctly. This is from your picture of the motor connection box.
                                  Top right U1
                                  Bottom right Z2
                                  Top middle V1
                                  Bottom middle U2
                                  Top left Z1
                                  Bottom left V2
                                  If I have this correct then this is what to do in the motor connection box.
                                  Remove the one wire from the reversing switch that I assume is still connected to the motor.
                                  Then remove the two metal links between V1 & U1 and between U2 and Z2 Be careful not to mix up any of the wires from inside the motor or from the capacitors.
                                  Connect the four wires as follows.
                                  A to U1
                                  B to U2
                                  C to Z2
                                  D to V1
                                  If you find that forward and reverse are the wrong way round then swap over wires C and D so that
                                  C goes to V1
                                  D goes to Z2
                                  I think it should be correct without having to do this.
                                  Les.
                                  #186320
                                  kevin large
                                    @kevinlarge76611
                                    Conect ed up forward now in forward position but no reverse
                                    #186323
                                    Les Jones 1
                                      @lesjones1
                                      Hi Kevin,
                                      Disconnect wires C and D from the motor and make them safe by putting them into some connector block or tape them up so they do not short to anything else or each other. Fit the link bars between U1 and Z2 and between V1 and U2 (At right angles to the the position that they were in. (As shown on the diagram on the connector box cover.) This is to confirm that the motor is wired as in the diagram in the cover. The motor should run in reverse with the switch in both forward and reverse positions.
                                      Les
                                      #186330
                                      Les Jones 1
                                        @lesjones1
                                        Hi Kevin,
                                        An alternative test you could do is to swap over wires C and D so that C goes to V1
                                        D goes to Z2 This is probably quicker to do. I would expect this to make the motor run in reverse when the switch is in the forward position and not work with the switch in reverse. Do you remember what sort of resistance reading you got when testing from the 4 wires to the plug pins ? I am wondering if there is a high resistance connection one one of the sets of contacts.
                                        Les.
                                        #186336
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi Kevin, not sure if you have the lever pointing in the right direction for forward and reverse. While all your contact now look to be correct, you seem to have the forward contacts correct for reverse and reverse for forwards. which way the lever is pointing does not matter really, however the manual designates that the lever is turned to the right for forwards and therefore A and C should be N and B and D should be L according to the box diagram on the circuit diagram. Les seems to be guiding you in the right direction for diagnosing your problem.
                                          Regards Nick.
                                          Edited By Nicholas Farr on 14/04/2015 02:07:46
                                          #186357
                                          kevin large
                                            @kevinlarge76611
                                            Checked connection this morning found 1 not crimped properly after that reverse working forward if I wiggled the switch would sometimes work after refitting switch to lathe reverse ok but forward just hums but does not turn ?
                                            kevin
                                            #186359
                                            Les Jones 1
                                              @lesjones1
                                              Hi Kevin,
                                              Are the connections as they were in your post at 20:38 on the 13th (Or have you swapped over wires C & D) ? Which connection was the bad crimp on ? I do not understand your statement "reverse working forward "
                                              Les.
                                              #186360
                                              kevin large
                                                @kevinlarge76611
                                                Hi les I connected a b c d as you said noticed 1 of the connections looked a bit dodgy re crimped and with the switch not bolted to the lathe reverse and forward worked although forward seemed a bit hit and miss after re bolting switch reverse fine in correct position forward just get a humming sound from motor even if I try spinning chuck it still doesn’t start I suspect the switch as every thing is connected as in your post
                                                #186365
                                                Les Jones 1
                                                  @lesjones1
                                                  Hi Kevin,
                                                  I too suspect the switch. With the switch in the reverse (CORRECTION – FORWARD ) position measure the resistance between the 4 wires in the motor connection box and the live and neutral at the plug.(Leave the wires connected to the terminals.) You will need to resolve quite low resistance values as the windings will now effect the readings. You should finish up with 8 resistance values. (Some may show very high values call these NC if they are outside the range of your meter.) Did you notice any manufacturers name on the switch ? (I suspect Warco will not have any in stock.)
                                                  Les.
                                                  Edited By Les Jones 1 on 14/04/2015 11:12:29
                                                  Edited By Les Jones 1 on 14/04/2015 11:14:26
                                                  Edited By Les Jones 1 on 14/04/2015 11:24:04
                                                  #186369
                                                  kevin large
                                                    @kevinlarge76611
                                                    Hi les
                                                    I didn’t see any name on the switch previous I set meter beap for tests shall I set it to 200 ?
                                                    kevin
                                                    #186372
                                                    kevin large
                                                      @kevinlarge76611
                                                      Also l noticed on meter the longer you leave the 2 test prong the reading changes to I take the initional reading or wait for it to settle
                                                      kevin
