Digital callipers shows time not distance
Home › Forums › Workshop Tools and Tooling › Digital callipers shows time not distance
  • #458714
    Speedy Builder5
      @speedybuilder5
      This is a new one on me, my cheapo digital callipers now show hours min and seconds instead of inches or millimetres.
      #19669
      Speedy Builder5
        @speedybuilder5
        #458716
        Nigel Graham 2
          @nigelgraham2
          That's so you don't miss whatever tea-breaks you've set yourself…..
          #458718
          jimmy b
            @jimmyb
            2.jpg1.jpgMine does the same………
            Jim
            #458719
            Former Member
              @formermember19781
              #458720
              Robert Butler
                @robertbutler92161
                That's a large caliper! Robert
                #458737
                Speedy Builder5
                  @speedybuilder5
                  Its Bigfoot's calliper.
                  #458742
                  V8Eng
                    @v8eng
                    Don’t if this will work in your case (different fault) but might be worth a try:-
                    My cheapo ones stopped changing readings whatever I tried, eventually out of desperation I left the battery out for a couple of days and everything worked fine when the battery was put back in.
                    Edited By V8Eng on 21/03/2020 21:55:40
                    #458755
                    Grindstone Cowboy
                      @grindstonecowboy
                      +1 on what V8Eng says. If you can't wait a day or two, you can try shorting out the battery contacts (with the battery removed, of course) to discharge any residual electricity. Worked for me on a couple of cheapo calipers.
                      #458756
                      Robert Butler
                        @robertbutler92161
                        It's not April 1st YET! Robert
                        #458758
                        Mick B1
                          @mickb1
                          Try closing the jaws and winding it back to zero with that big winding button on the top….
                          #458771
                          Hopper
                            @hopper
                            Posted by Robert Butler on 21/03/2020 22:31:40:
                            When you stand on the corner of Space and Time, it's always April 1.
                            #458776
                            Bob n About
                              @bobnabout
                              Jimmy, would you be a Leprechaun by any chance.
                              #458777
                              Joseph Noci 1
                                @josephnoci1
                                Maybe measuring the speed of light tween the caliper tips? Measure up your foot – should read around 1ft or so, or maybe 1nanosecond…
                                #458778
                                jimmy b
                                  @jimmyb
                                  Posted by Joules on 22/03/2020 04:56:08:
                                  No Joules!
                                  Mitutoyo give them away free. You ony have to spend £100,000 on a CMM to get one!
                                  Jim
                                  #458818
                                  mgnbuk
                                    @mgnbuk
                                    Almost the correct answer – our CMM at work was "only" £42,000 + Vat & came complete with the complimentary caliper shaped wall clock. Fortunately the CMM has lasted longer than the clock !
                                    Nigel B.
                                    #458822
                                    Mike Poole
                                      @mikepoole82104
                                      Is that Donald Trumps hand in the picture.smiley
                                      #458836
                                      Howi
                                        @howi
                                        put a strap on it and you have the trendiest watch going, plus you will be able to tell the time to the nearest millimeter.
                                        #458926
                                        Georgineer
                                          @georgineer
                                          Do they do a left-handed version?
                                          George B.
                                          #458946
                                          Howard Lewis
                                            @howardlewis46836
                                            I'll second (PUN!) what V8eng says.
                                            #458947
                                            Mick B1
                                              @mickb1
                                              Posted by Howard Lewis on 22/03/2020 18:00:34:
                                              The Secretary had better minute that, then…
                                              #459308
                                              Mark Gould 1
                                                @markgould1
                                                Are you sure it’s hours, minutes and seconds? It could still be showing size, just in degrees, minutes and seconds. Have to be pretty big mind you
                                                Mark
