Creating negative pressure in flue?
Home Forums General Questions Creating negative pressure in flue?
  • #497043
    Peter Bell
      @peterbell11509
      I have a vehicle type Webasto diesel heater which really does not like operating on a 3" dia vertical flue due to back pressure. I had thought of making a steam raising type blower with a variable speed 12v motor to put on top of the flue as an experiment. to create a slight negative pressure but have no experiance of these.
      However on the steam raising designs looked at all the flu gas passes through the fan, is this decremental on the fan? Was going to put the motor on top
      Are there are any alternative designs around using an ejector or similar which means the fan is on the clean cool bit just supplying air?
      Can anyone offer any advice before I start? Thanks
      Peter
      Edited By Peter Bell on 21/09/2020 13:37:46
      Edited By Peter Bell on 21/09/2020 13:38:37
      #27641
      Peter Bell
        @peterbell11509
        #497064
        Dave Halford
          @davehalford22513
          Have you considered the carbon monoxide might get you if you do it wrong.
          #497076
          Robert Atkinson 2
            @robertatkinson2
            I concur with Dave.
            Put the heater outside and run the hot water inside. If it's an air heater stll put it outside but get a carbon monoxide alarm as well. A relative of mine died from CO due to a modification to a heater. Not the way I wanted to inherit his watch making tools.
            Robert G8RPI.
            #497085
            Clive Brown 1
              @clivebrown1
              Posted by Peter Bell on 21/09/2020 13:36:22:
              I have a vehicle type Webasto diesel heater which really does not like operating on a 3" dia vertical flue due to back pressure..
              Peter
              Are you sure that you've diagnosed the problem correctly? Don't Webastos on vehicles and boats normally operate with fairly lengthy exhausts much less than 3" dia?
              #497088
              Peter Bell
                @peterbell11509
                Thanks everyone for your help.  Perhaps I should have said it was on a test rig outside but I didnt think I needed to to ask about a fan!   Peter
                Edited By Peter Bell on 21/09/2020 18:35:22
