Posted by Martin Dilly 2 on 09/10/2019 22:33:17:
Thanks to the rest of you, too. I suspect it's a case of chinesium, which may defeat my best efforts.
Could be! I'd love to put those blades in front of an Alloy Analyser.
I suspect there are a number of explanations. In the good old days Chisels were made from Tool Steel. This is a simple carbon-steel, straightforwardly mass produced cheaply at high quality since about 1880. Although easy to harden by heat treatment and good at holding an edge, it's fallen into disfavour, for example cutlery and working knives are rarely made of it, and the same may be true of chisels. Reasons for falling out of favour include staining, prone to rust, excessive brittleness, poor heat performance, and high maintenance. (Frequent resharpening needed.)
Nowadays most small kitchen knives are made from stainless steel. Eating knives are rolled from a soft stainless alloy and won't take an edge. Sharp knives are made from a very hard stainless alloy that isn't as easy to sharpen as carbon-steel. Neither of the stainless alloys used respond to heat treatment. They're semi-disposable – when sharpening is needed it may easier to buy a new knife.
Martin's chisels are likely made from an Alloy Steel. The manufacturer might have valued rapid factory sharpening and not snapping in customer hands more than making the best possible wood-chisels. If it's an alloy steel, it may not behave like an ordinary engineering steel during heat-treatment. If you don't know what a steel is, all bets are off.
Alloy steels with non-standard properties have been squeezing the more ordinary steels out of manufacture for at least a century. A 1938 Austin is mostly dead-mild steel, mild steel, cast-iron, and a sprinkling of specialist steels for springs, gears, and shafts etc. Nice and simple. A modern car contains a much wider mix of specialist metals, each chosen carefully to maximise performance and safety at minimum cost. Boron steels and other fancy manufacturing techniques may be marvels in the right place, but they' can be downright unfriendly in a home workshop! Those Chinesium chisels may be from the same camp: cheap replaceable tools cost-cut for light amateur use, not intended to make professionals happy!
By all means experiment but don't be surprised if the metal doesn't behave with textbook simplicity. Please let us know what happens, good or bad.
