Could anyone let me know what these are
Home › Forums › Beginners questions › Could anyone let me know what these are
  • #433889
    Philip Sewell
      @philipsewell33761
      wp_20191014_16_33_29_pro (2).jpgThese parts came with a mill I bought and I've never found out what they are. I realise one of the parts screws into the int 40 tool holder, how does a draw bar connect onto it.
      I've no idea what the other things are.
      Any ideas,
      Thanks
      Philip.
      Edited By Philip Sewell on 18/10/2019 21:53:12
      Edited By Philip Sewell on 18/10/2019 21:57:21
      #9896
      Philip Sewell
        @philipsewell33761
        #433890
        John Haine
          @johnhaine32865
          Hard to say without photos! But it may be a fitting to use the 40int taper with an automatic change tool holder system.
          #433894
          John Haine
            @johnhaine32865
            Aha! Better. The thing on the right is a pull stud for an int taper toolholder to adapt it for use in an ATC on a CNC mill. The drawbar has a clip on the end that grabs it. Other bits look they might be alignment aids.
            #433970
            Martin Connelly
              @martinconnelly55370
              If the flat topped tool is a metric or imperial length (measured to a reasonable tolerance) it may be a height setting pillar for items that are quite tall when clamped to the machine bed.
              Martin C
              #433977
              Philip Sewell
                @philipsewell33761
                Ok I now understand how the pull stud works, it helps when you know the name of something to google it, thanks.
                I'll check the height of the l/h tool tomorrow, I wonder why the r/h tool is turned to a point. Also, why have flats been machined on the bases, and grooves machined in those flats.
                Philip.
                #433980
                John Haine
                  @johnhaine32865
                  Do the bases fit Tee slots perhaps?
