Correct way to do shrink fitting as replacement on plug welding
Home › Forums › General Questions › Correct way to do shrink fitting as replacement on plug welding
Viewing 2 posts - 1 through 2 (of 2 total)
  • #628613
    abdu arrahman
      @abduarrahman80038
      Anyone experience how to accomplish join correctly of two wide rings piled up the smaller diameter one on the larger one just by the way of plug/slt welding but here and now the join work and method is replaced by the shrink fitting from ambient temperature to other greatly different one thence it's being fitted before getting back to the ambient
      ring 1
      hole d = 20 mm
      OD = 30 mm
      thickness = 1.5 mm
      ring 2
      hole d = 20 mm
      OD = 55 mm
      thickness = 2.5-3 mm
      #28994
      abdu arrahman
        @abduarrahman80038
        Seek for possible correct way to do shrink fitting as replacement on plug welding
