Copper from hot water cylinder
Home › Forums › Materials › Copper from hot water cylinder
  • #235640
    Steve Pavey
      @stevepavey65865
      I had to change my hot water cylinder a little while ago and the old one is sitting behind the workshop waiting for either a trip to the scrappy or to be cut up and put into the stock of stuff that might come in handy. But is it any good for anything?
      #29593
      Steve Pavey
        @stevepavey65865
        #235642
        JimmieS
          @jimmies
          Money! Worth enough to treat yourself to a few bits and pieces. Some while ago I got £35 for one.
          Ops – just noticed you had this thought too. Old age and excitement don't mix too well.
          Edited By JimmieS on 21/04/2016 21:44:11
          #235659
          julian atkins
            @julianatkins58923
            I am currently making a tank to go inside a 5"g LBSCR wagon to go behind my current build – all made out of an immersion heater cut up and flattened out. It is give or take a thou 1/32" thick.
            Cheers,
            Julian
            #235666
            Bazyle
              @bazyle
              One of our club members at the last meeting showed a small smithies boiler made from water heater shell. Not the pressure vessel but the shrouding.
              Also there used to be a nice 4ft long tug on the local pond with the hull made from a tank. Terrible waste to just scrap it for a little money. While still in sheet form it has far more potential.
              #235682
              Gordon W
                @gordonw
                Quite agree- keep it for the material, expensive if you have to buy it. My question is how to get the insulation of the modern ones ? The last one I cut away most of the foam with a bread knife and burnt the rest. Awful mess and and a long clean-up.
                #235728
                Ian S C
                  @iansc
                  You would have to check the inside for corrosion, an old hot water cylinder can be a bit like a lace curtain, if its got one hole, it's got hundreds about to become holes. If it's sound keep it, if not sell for what you can get.
                  Ian S C
                Home › Forums › Materials › Topics
