Colchester chipmaster dual dials
Home › Forums › General Questions › Colchester chipmaster dual dials
  • #359335
    Adam
      @adam
      Hi everyone. I have a Colchester chipmaster I recently acquired and I measured the distant on the slide with respect of the dual metric imperial dial. It says one revolution is 400 thou but it’s actually half that.
      Is this normal?
      #26052
      Adam
        @adam
        #359337
        Bill Davies 2
          @billdavies2
          Hi, Adam.
          Assuming the cross slide, the dial movement indicates the amount removed on the diameter. Half off radius (actual slide movement) equals amount off diameter.
          Bill
          #359338
          Muzzer
            @muzzer
            Yes – it takes 400 thou off the diameter, which is often what you want on a lathe.
            Murray
            PS – I've never checked on my Bantam but I assume the compound / top slide is different ie direct reading, as it could move at any angle to the axis.
            Edited By Muzzer on 24/06/2018 21:55:40
            #359363
            John MC
              @johnmc39344
              My Chipmaster has dual dials, takes 400 thou off diameter. While the imperial dial is accurate the metric is not. If I zero the dial in "thous" then the cross slide will consistently return to the zero position, checked with a DTI, zero on the metric scale is inconsistent. Anyone else noticed that? I tend to use the DRO so not a problem, would be nice if it was accurate on both scales.
              My Triumph has dual dials fitted, absolutely consistent in both ranges.
              Adam
                @adam
                Of course!! It’s diameter!! This is my first real lathe so I’m still learning. I guess we all start from somewhere. Thanks for the responses. No doubt I’ll ask more easy questions later.
                #359390
                  Posted by Adam on 25/06/2018 10:15:48:
                  Of course!! It's diameter!! …
                  No 'of course' about it. Traditionally British lathes measure depth of cut. Measuring diameter (which I find more natural except when cutting threads) is a beastly American innovation circa 1890.
                  My Chinese mini-lathe dial measured depth, it's big brother measures diameter. Not much consistency in the world of lathes.
                  Always worth double-checking before using an unfamiliar machine.
                  Ian S C
                    @iansc
                    My Taiwanese Lathe indicates diameter, and I got trapped when I did some work on a mates Myford 7 that indicated DOC. I'll have to check the Menzshed Boxford A, the dial is tiny, and not easy to read.
                    Ian S C
