Choosing an MMA Welder
Home › Forums › Manual machine tools › Choosing an MMA Welder
  • #727314
    hejay
      @hejay
      Hey all, I need to make some aluminium and steel jigs and frames out of tubular steel and don’t know what MMA welder to go for. Needs to be 240V and have a duty cycle that’s not agonising. Other than that, can be new or used.
      #727329
      noel shelley
        @noelshelley55608
        You make no mention of materisl thickness or the number to be made. For a quality job I would say inverter Fusion at Honiton The 175A is good and has a guarantee at about £500 . There’s cheap far east, or a old transformer unit BOMB proof and second hand = cheap, must be oil filled. Tube, I would also look at a GOOD MIG set. Noel.
        #727370
        Robert Atkinson 2
          @robertatkinson2
          MMA is a very poor choice for aluminium.
          #727509
          noel shelley
            @noelshelley55608
            Following Roberts comment I agree. If aluminium is being used then there is only really one process that will work well if using electric, TIG ! AC TIG ! I recently bought a cheapish machine that has worked well and depending on what extras you add will do TIG, MIG and MMA at up to a CLAIMED 250A !This machine also claims to need 28A at 240V but is supplied with a 13A plug that does NOT even get warm when running at a setting of 250A ! Alli can be welded using MMA but is is messy and rods are expensive. If you use TIG or MIG you will need a supply of ARGON gas and unless you are a skilled welder you will need some time to get the hang of it. Working on 1/4″thick material I needed the claimed 250A. It was a ROHM 250 WSME. Noel.
            PS If you go for TIG  then avoid a scratch start type, go for high frequency start, the former will work but soon gets tiresome to use. N
            #727519
            Dave Halford
              @davehalford22513
              You should be asking here
              #727522
              DC31k
                @dc31k
                On noel shelley Said:
                TIG ! AC TIG ! 250A ! 250A !
                I am not a welder, but is TIG with an exclamation point bigger or better than TIG without that embellishment?
                Similarly, are 250 A! better for welding than 250 of Mr Ampere’s standard product?
                #727525
                Oldiron
                  @oldiron
                  #727529
                  duncan webster 1
                    @duncanwebster1
                    I don’t think mocking someone’s punctuation actually helps
                    #727541
                    Harry Wilkes
                      @harrywilkes58467
                      Agreed
                      H
