Chemistry question
Chemistry question
Home › Forums › Beginners questions › Chemistry question
  • #7044
    AB658
      @ab658
      Citric acid pickle
      #144332
      AB658
        @ab658
        I'm having great success with pickling silver-soldered steel parts in a strong citric acid solution used hot (90C-ish) carefully, with PPE. Quick & effective at cleaning off superficial rust, HT5 flux and SIFbronze brazing flux where unsuccessfully attempted that process first. And won't be problem on disposal.
        What is the gas evolved during pickling?
        Adrian
        #144333
        jason udall
          @jasonudall57142
          Depends on what your pickling…
          Metals in acids react to give off hydrogen
          Carbonates.. ( some fluxes) give off carbon dioxide…..
          A part from water vapour
          and a little mist of acid ,..thats about it
          #144334
          jason udall
            @jasonudall57142
            But given that you use the term “evolve”..my guess is that you knew that
            #144340
            AB658
              @ab658
              Thanks Jason. I'm doing this in a double garage built under our bedroom suite & I'm concerned about hydrogen, although the scale of the exercise is probably not big enough to form an explosive mixture. I've turned off the dehumidifier and the PIR sensors to remove obvious ignition sources and perhaps I will open one of the doors, despite the weather. Adrian
              #144347
              jason udall
                @jasonudall57142
                Just a thought..say one mole of copper reacted ( can’t remember coppers valency..) means one mole of h2 gas…thus 70 gram of copper reacted gives one mole or 22 l of gas.. just how many moles of h2 is related to valency of copper or what ever metal is being reacted but thats either 22 l or 44 l..so for our purposes 44 l worst case..how bigs your “shed”..say 8x6x6….thats 7.7 m3 or 7700 l
                .so 44 l means something like 0.5% ..
                I don’t know what is the threshold for h2 but I would expect it much higher than that. ..anyone?
                Edited By jason udall on 18/02/2014 20:16:12
                #144353
                AB658
                  @ab658
                  It's exactly 50 years since chemistry 'O' level, after which we parted company…. The black steel items being pickled have no more than 40mm of exposed solder bead (CuP Alloys' 455) each and there are 4 of them at a time; no other source of Cu. Most of the gas appears to come from the steel surfaces.
                  After 2 hours the mixture is cool, gassing has ceased, the surfaces are clean & ready for a rinse, a quick rub with emery and paint. And the building is still standing…..
                  Thank you for help.
                  #144355
                  Nicholas Farr
                    @nicholasfarr14254
                    Hi, this **LINK** may help, 4-77%/Vol of air is the flammable range.
                    Hydrogen is one of the gases you must never snift when contained in portable gas cylinders. Please do remember that it is lighter than air and will rise and accumulate into the roof/ceiling space rather than float out of the door.
                    Regards Nick.
                    #144357
                    Michael Cox 1
                      @michaelcox1
                      Hi Jason,
                      Metallic copper will not react with acids to produce hydrogen. Acids will dissolve copper oxide, without producing hydrogen and they will react iron ,steel, zinc and aluminium to produce hydrogen. Only oxidising acids such as nitric acid will react with copper but they do not then give off hydrogen but some reduction product like nitric oxide.
                      If you are pickling with citric acid normal sized ME objects, ie less than circa 0.5 square metre surface area it is unlikely that hydrogen build up would be a problem. Because hydrogen is so light it disperses very rapidly. However, it is prudent to take sensible precautions to avoid build up in confined spaces ie do not cover containers, ensure good ventilation etc. and avoid naked flames and sparks.
                      #144362
                      jason udall
                        @jasonudall57142
                        Thanks Mike
                        I know( or assumed)
                        Not just copper . But couldn’t for the life of me remember the gram molecular weight for “steel”..used copper as example..
                        If citric acid does not evolve h2 with copper then that’s in the right direction for Adrian
                        The amount with iron ( steel) is so small unless confined I think we can agree the risk is minimal
                        #144366
                        Trevor Drabble 1
                          @trevordrabble1
                          Adrian,
                          Appreciate we are probably only talking about small amounts of gas here , and the risk of an untold occurance is therefore low , but would still like to supplement the excellent information and guidance already offered. Think your decision to work with an open door is a most prudent one . Regarding the hydrogen , please note that IT burns with an invisible flame , which is why we were instructed to approach a suspected hydrogen fire with an outstreched roll of paper so that it would act as an indicator. With respect to the nitric oxide ( nitogen monoxide ) , please note this really can be rather naughty. It is an oxidiser , corrosive to the respiratory duct , and can also cause severe skin burns as well as eye damage . And then , just by way of a bonus, it can cause / intensify a fire. Given all these issues , I believe good and consistant ventilation to be an essential requirement. Just by way of a small additional piece of information , at work we were unusual in that we had a fully piped nitric oxide system ( arranged in 2 x 4 banks of equivalent J size cylinders) feeding into the neonatal critical care unit . For a number of reasons its use was discontinued and we reverted back to the original very small cylinders.
                          Trevor.
                          Edited By Trevor Drabble on 19/02/2014 00:47:43
                          #144373
                          Gordon W
                            @gordonw
                            I can't imagine the amount of gases will be any more dangerous than charging a car battery, but take all reasonable precautions.
                            #144379
                            JA
                              @ja
                              Not only is Hydrogen very light compared with the atmospheric gases but its molecule is very small. That means a Hydrogen molecule will travel a long way before hitting an Oxygen or Nitrogen molecule. Therefore any Hydrogen will disperse widely and quickly into the atmosphere and disappear.
                              Keep the door open anyway.
                              JA
                              #144382
                              MICHAEL WILLIAMS
                                @michaelwilliams41215
                                A
                                Danger / very small / main acid splashes / rust .
                                Fume cupboard / cardboard box / pipe / window / chimney / blower .
                                Wet towel / bathroom /outside .
                                Burn off / catalytic / pilot burner /
                                M
                                #144434
                                Robin Graham
                                  @robingraham42208
                                  Some ballpark numbers – citric acid is trihydric with a molecular weight of around 200. So 200 grams of acid could potentially yield about 1.5 mols of H2, or around 30 litres (0.03 cubic metres) at STP. That would be 3% by vol in a 1 cubic metre space, just below the lower threshold for a flammable mixture given by Nicholas above. Say a double garage has a volume of 30 cubic metres. It would need 30*0.2 = 6kg of citric acid to be consumed to get to the 3% level – assuming the garage is hermetically sealed! So I doubt there is a problem.
                                  Regards, Bob
                                  #144441
                                  AB658
                                    @ab658
                                    Seek and ye shall find: many people who know more than you do…..my thanks to you all. You have confirmed that the scale of what I was doing was not potentially dangerous; and you have given me the capability to calculate the likely risk if I undertake a bigger job in future. Adrian
