Cheers from Switzerland
Home › Forums › Introduce Yourself – New members start here! › Cheers from Switzerland
  • #727961
    chrissie
      @chrissie
      Gentlemen,
      I’ve updated my profile to cover the basic biographical info. Male, two sons, two grandsons.
      Starting 2024, I’ve picked up the hobby of building model engines and started with Beng’s “Danni” steam engine, which I finished succesfully two weeks ago.
      My little workshop includes
      Scheppach DP18 Vario bench drill
      Paulimot DP190-V Lathe
      Noname (aliexpress) bench drill up to 16’000 rev/min for smallest diameter work.
      I found this forum when I was looking for some fellow “Danni” builders …
      #727977
      noel shelley
        @noelshelley55608
        Welcome To the show sir, if you have any questions, just ask. Some one will be able to answer. Where abouts in Switzerland are you ? Best wishes Noel.
        #727990
        chrissie
          @chrissie
          Noel,
          thanks for your welcome.
          I moved to Haslen, Appenzell-Innerrhoden three years ago. Before that, seven years in Beringen, Schaffhausen. Before that, life in Germany.
          Best,
          Chrissie
          #728016
          Howard Lewis
            @howardlewis46836
            Welcome! As Noel says, any questions, just ask. Someone will be able to help.
            Are there Model Engineering Clubs in your part of the country?
            If there are any within easy travelling distance, do join to be with like minded people.
            #728049
            chrissie
              @chrissie
              Good morning Howard,
              Switzerland seems to have a culture of maintaining publicly accessible workshops, where you can use workspace, equipment and sometimes advice. They are organized in different formats, some are partly supported by public funds, the rest comes from volunteer work, yearly membership fees or (for non-members) at a half-day / full day rate, which can get quite expensive actually. And so I frequently opt to  _buying_  a needed tool for my little private workshop. 12 km away in St.Gallen there is such a public workspace with a dedicated woodworkshop, metal workshop, pottery and textile workshop. The metal workshop is rather well equipped with all kinds of welding equipment. The also have a sufficiently sturdy boring/milling machine, which btw. I used to machine the flat side of my steam engine “Danni”‘s flat surface of the cylinder, where the steam chest gets soldered onto. Other than that, there’s really noone at this place who is into the kind of precision manufacturing that a little model steam engine requires. So I’m not overly enthousiastic about working in an environment with sparks flying around my ears and oftentimes really loud hammering, flex grinding etc..
              May I point your attention to a 1st comment of mine, at the end of this thread on this forum? That may give you an impression of where I currently stand …
              Other than that, I have a blog where I post about my little adventures. This blog post shows me running “Danni” from the power of my lungs/diaphragm 💪, and this little video shows when I finally found out how to run “Danni” with much less strain with the help of a bicycle pump 🤓.
              Chris
              #728076
              Howard Lewis
                @howardlewis46836
                Chris, you and your neighbours are SO fortunate.
                I, for one, am envious!     Have always held Swiss engineering and precision in very high regard (Which is why, there are a couple ex industry Compaq instruments in my collection)
                In Britain, although the bitrthplace of the industrial revolution, Engineering is not held in the same respect.
                So we have to be proud in private, amongst our associates.
                Sadly, keyboards are worsening the situation among the younger generation, and we are losing old skills.
                Gets down from hobby horse.
                #728273
                Roger B
                  @rogerb61624
                  Hallo Chris,
                  I am in Pfäffikon ZH. My main interest is model internal combustion engines. I mostley post on MEM, Model Engine Maker
                  Roger
                  #728275
                    Thanks for linking that, Chris
                    The animation is exquisite, and displays perfectly on my iPad
                    Where you currently stand is clearly towards the peak !
                    chrissie
                      @chrissie
                      Hoi Roger,
                      I know model ICE only from my early RC model aircraft times, although only in the commercially available kind like OS PET, OS MAX and Cox types. Manufacturing those probably comes with some challenges of their own. Since I’m only starting at manufacturing engines myself, I thought steam engines would be a good start. Especially as long as you cut out the steam part, and resort to compressed air or the power of your lungs/diaphragm.
                      Pfäffikon isn’t really out of the way from where I live. Across Wasserfluh mountain pass and Hulftegg pass this would even make for a nice ride on my Ducati Monster, if you’re interested.
                      Chris
                      #728296
                      chrissie
                        @chrissie
                        Hi Michael,
                        thanks for your appeciation (blushing).
                        The nice thing about animations is, that you as the author have an arbitrarily large number of trials befor you finally get it right. Whereas in reality, one mis-placed bore or too much material taken away while lathing or milling makes you have to start all over again. That said, don’t deduce my crafting skills from the quality of my animation…
                        Chris
                        P.S.: the screen menu cosumes a fixed amount of screen space in terms of pixel width and height, which on a small screen like a mobile phone’s may overlap the animation. So people may turn away in disappointment before they find out that you can close the menu by clicking on “Controls”, top of menu, too.
                        #728410
                        Roger B
                          @rogerb61624
                          On chrissie Said:
                          Hoi Roger,
                          Chris
                          There are some pictures of what I have made on here:
                          https://www.flickr.com/photos/153503473@N05/
                          And a load of random videos on here:
                          https://www.youtube.com/channel/UCy1iujii6Z-pRikcGx-9kTQ
                          I am on holiday for the next couple of weeks, maybe we we can arrange to meet up after that.
