Ceramic material for burners
Home › Forums › General Questions › Ceramic material for burners
  • #29020
    nigel jones 5
      @nigeljones5
      #631697
      nigel jones 5
        @nigeljones5
        Does anyone know of a stockist, supplier or manufacturer of soft ceramic tiles used in burners? Our supplier has cesed trading and ive looked everywhere for an alternative. The hard ceramic tile doesnt work – they melt. The only ones which can deliver the required heat output are those which crumble if you rub them. If we cant source these then its back to the drawing board for all of our twin boiler burners. Thanks, Nigel at PSB
        #631700
        David George 1
          @davidgeorge1
          Have you tried Cousins. Have a look if this is whst you need.
          https://www.cousinsuk.com/search?searchTerm=Soldering%20Blocks%2C%20Boards%20%26%20Pads
          David
          #631704
          duncan webster 1
            @duncanwebster1
            Try British ceramic research association, now known as Lucideon. They should know.
            #631710
            GordonH
              @gordonh
              Nigel,
              Might be worth looking at Scwank:-
              https://www.schwank-burners.com/en/
              Gordon
              Added link text
              Edited By GordonH on 02/02/2023 10:05:07
              #631718
              bernard towers
                @bernardtowers37738
                seems to be quite a few suppliers on the bay
                #631738
                Raymond Griffin
                  @raymondgriffin40985
                  I purchased a sheet from Polly Model engineering some years ago. Still using it. They have it in their catalogue but P.O.R. Great material for burners. Cuts easily with a fine saw.
                  Ray G.
                  #631752
                  nigel jones 5
                    @nigeljones5
                    Thanks all – I ujsed to get mine from Polly but with their massive scaling back due to the owners retiring they no longer stock it. There must be somewhere else to get it from but no luck thus far.
                    #631758
                    Baz
                      @baz89810
                      Fizzy can’t you ask Polly where they got it from, or won’t they tell you.
