Cast Iron Pulley Repairs
Home Forums Help and Assistance! (Offered or Wanted) Cast Iron Pulley Repairs
Viewing 21 posts - 1 through 21 (of 21 total)
  • #250890
    MW
      @mw27036
      Hi, just a small thread demonstrating some of the uses of epoxy putty and where a more substantial solution is needed.
      Things have been quiet lately so I've been getting round to those jobs that should've been done a long time ago but things got in the way.
      One of them was repairing 2 broken 5" cast iron step pulleys, it's an accident on my machine that happened a long time ago when i first got it, since i've changed the motor and shes been hobbling along on a single large aluminium pulley from machine mart.
      Not that there's anything wrong with an aluminium pulley, just that i'd rather have the steps back for lower speeds and the cast iron. They weren't badly damaged to the point of "bin them", but badly enough that it couldn't be ignored without tearing the belts to shreds on the sharp corners and possibly jumping off on the worse of the two.
      Now it didn't have to look pretty, it just had to be sound again. My first solution, on the first, worked alot more neatly than i thought it might. I reached for the epoxy putty, put some on and waited a day for it to fully cure, i came back to it and filed it flat to the Vee form by spinning it in the machine.
      As you can see, it's totally flush with the body, and its a very strong bond. It's appropriate to use this on it with a single chip, as theres enough land around the breakage to support the bond.
      Now for the second, that just wasn't the case, this was battered and beaten to the point of no return for the front vee. I didn't take a picture with the damage but i can show you a photo of the piece i sawed off, to give you an idea.
      The "wheel" form had been so badly damaged, that putting putty around it just wouldn't be appropriate, i've tried this with repairs in the past, and it just breaks off if you're having to form a large area with it.
      I thought about bolting a piece of plate metal to the front. But it would be a little on the flimsy side at 1 or so mm thick and wouldn't create a vee. So i noticed a little, not much, 2.5mm of land on the pulley after cutting off, so i created an aluminium "half form" on the lathe, i measured the angle to be around 13.5 degrees. And loctited a push fit onto the pulley.
      Hopefully this will help those of you who frequently need to repair things like myself!wink
      Michael W
      #32761
      MW
        @mw27036
        #250893
        Vic
          @vic
          Nice job on both pulleys. smiley
          #250897
          MW
            @mw27036
            Thanks vic,
            I had thought about silver soldering but as far as i'm aware i vaguely remember reading somewhere that only bronze filler metal is appropriate for cast iron brazing, and i wouldn't have a torch hot enough to melt that anyway.
            Something i forgot to mention is that both pulleys also had a coat of rust which i was easily able to take off with a little ally oxide abrasive paper and spinning them, whilst keeping your fingers well clear of "the crocodiles mouth" as i call it (jaws of the chuck).
            Michael W
            Edited By Michael Walters on 15/08/2016 19:31:45
            #250898
              Posted by Michael Walters on 15/08/2016 18:40:36:
              … So i noticed a little, not much, 2.5mm of land on the pulley after cutting off, so i created an aluminium "half form" on the lathe, i measured the angle to be around 13.5 degrees. And loctited a push fit onto the pulley.
              Neatly done, Michael
              But; in the spirit of the recent thread started by Danny M2Z **LINK** … Could you please identify the grade of Loctite used, and any pre-treatment, etc.
              … It all adds to the pool of knowledge.
                Michael W, you can silver solder CI, just needs the carbon bringing to the surface and then removing before soldering.
                Got to ask, you said you wanted iron pullies rather than aluminium so why did you use aluminium for the repair and not a bit of CI bar?
                J
                #250900
                MW
                  @mw27036
                  Hi Michael G,
                  I don't think i'm quite seen as a pillar of the forum community so i'm hoping i will get away with brand naming here but it's the closest thing i can get to a grade.
                  The only thing i can list as pre-treatment would be to wipe away any grease with a tissue and only apply on a dry surface, would probably be a sensible idea.
                  And to make sure it's a reasonably tight fit to begin with, where you know the part will be under a certain load.
                  Michael W
                  Edited By Michael Walters on 15/08/2016 20:02:17
                  #250902
                  MW
                    @mw27036
                    Posted by JasonB on 15/08/2016 19:43:25:
                    J
                    Hi Jason,
                    Ah, well i knew i wasn't well versed on the subject so thanks for filling the knowledge gap there.
                    I didn't see anything wrong with an aluminium pulley as such, i just wanted my old ones back because they were made with the machine, and quite simply, i admit only have a stock of non ferrous materials in the larger sizes!
                    Michael W
                    Edited By Michael Walters on 15/08/2016 19:54:46
                    #250909
                      Posted by Michael Walters on 15/08/2016 19:47:22:
                      Hi Michael G,
                      Thanks, Michael yes
                      … given that Loctite is, itself, a brand name; I really can't see anyone objecting to you naming the brand that you actually used [and mis-identified as 'loctite'].
                      Ajohnw
                        @ajohnw51620
                        I had photo one happen to a cast iron pulley. 2 in fact. I milled a sector away so that there was enough flat to attach a piece of plate with cs machine screws. Ran it up on a turned up mandrel and machined back the od and the V.
                        If the epoxy breaks off you could do much the same thing or create the flat on a rotary table if there isn't enough room to just machine straight across. The screws need to be about 1 1/2 to 2 diameters in.
                        If there wasn't much room I would probably use M3. From memory I used M4.
                        Edited By Ajohnw on 15/08/2016 20:38:20
                        #250914
                        MW
                          @mw27036
                          Thanks john, it sounds like your thinking came to a similar solution, as i was thinking about bolting something onto it. I have used your method before for repairing broken shafts by machining the other end to suit after the bond is made, to ensure a proper match.
                          I like to create posts like this, because you don't necessarily always want to read about the projects that go right, as inspiring though they may be. You want to read about what you look for when things don't go right, so that you may put them right.
                          There have been quite a few occasions where i've gone wrong and i haven't a clue how to approach it once it does. I would like to think that a voice of experience, would mean not only be good at making wonderful things, but also have the answers to these problems.
                          I guess when it comes down to it, breaking and then fixings things, has just as much a place in engineering as making the things themselves.
                          Michael W
                          Edited By Michael Walters on 15/08/2016 21:05:00
                          #250972
                          Ian S C
                            @iansc
                            Just looking at the pulley with the bite out of the rim, A disc about 1.5 mm thick on the outside could be a worth while reinforcement, held in place with suitable sized countersunk screws. Good job, well done.
                            Ian S C
                            #251047
                            MW
                              @mw27036
                              Well Ian, i think i may actually take you up on that idea, it sounds like it could only help in the long term what with a tensioned belt going round it everyday.
                              I'm just waiting for some new screws, the stainless ones i used to buy break without much force being put on them. So i'm taking a new approach and going with high tensile bolts, and counter sunk rather than round head for greater pressure i suppose.
                              Thanks
                              Michael W
                              Edited By Michael Walters on 16/08/2016 19:58:17
                              #251055
                              Ajohnw
                                @ajohnw51620
                                I like countersunk screws for some thing MIchael as they clamp and locate. Best to do holes for tapping and the countersink in one setting which may be a pain or use a temperary ordinary bolt etc in another hole if clamping up is a problem. Super glue might hold things together well enough too.
                                Ian S C
                                  @iansc
                                  Best screws I find are countersunk Allen head type, if possible use a coutersink bit the same diameter as the head, the drill it down just a whisker bellow the level of the parent metal so that when the screw is in place it is flush. With thin metal the pulley it's self may also end up with a bit of the countersink, you may hve to clear the threads. You probably should use a coarse thread into the aluminium, my choise would be 10 24 UNC, but 3/16" Whitworth would come next, you might find 5 mm the easiest to find.
                                  #251357
                                  MW
                                    @mw27036
                                    So i'm thinking of making this reinforcement plate from sheet steel, when i'm probably stumped by how to do this. I've got my 1mm sheet steel, can cut and finish the outer rim of the circle, but what to do about the inner rim? how to remove a circle of material that big, and a piece of material so thin.. how to get rid of it without spoiling the outer circle? Can't figure that out, may be nibblers are a good idea after all.
                                    Maybe just drill a centre hole, and cut triangles away using a hacksaw then smooth out with a file?
                                    Michael W
                                    Edited By Michael Walters on 18/08/2016 17:40:49
                                    #251366
                                    Ajohnw
                                      @ajohnw51620
                                      crook Maybe a hole saw. Toolstation do some that aren't too bad and cheap. Or get a trepaning tool, clamp the work down well, do centre hole first and outer rim last. The cutter in the usual ones are often not much good but a fresh one can be ground. They need using with a bit of care.
                                      Edited By Ajohnw on 18/08/2016 18:04:01
                                      #251369
                                      Andrew Entwistle
                                        @andrewentwistle
                                        Or if you have a large enough chuck install a roughed out disc onto the pulley and bore in situ, or with a boring head on a milling table.
                                        Andrew.
                                        Edited By Andrew Entwistle on 18/08/2016 18:27:53
                                        #251374
                                        MW
                                          @mw27036
                                          Can't believe i forgot about them john, well i am a lucky bugger, the hole size is 38mm which i happen to have.
                                          Little job for tomorrow then.
                                          Michael W
                                          #251494
                                          Ian S C
                                            @iansc
                                            Drill the holes for the screws, then get a bit of wood/MDF, and using the screw holes attach the disc to the wood and hold it in the 4 jaw, or screw it to a face plate in a way that it can be centered, you should be able to cut out the 1 mm thick metal with a general purpose tool, at 1 mm an ordenary parting tool would manage it. Just go carefully as it breaks through, it rarely goes through all in one go, and the tool can catch and tear the disc off the wood.
                                            Ian S C
                                            #252016
                                            MW
                                              @mw27036
                                              So i got round to finishing these repairs, by first adding the steel plate, as recommended: I tried to rotate them but the formatting hasn't transferred over to here this time round so everything is sideways.
                                              It looks alot neater than looking at the epoxy i have to admit. I tried to use countersunk screws but unfortunately without having a "punch" to press the shape into the metal first, the threads were too fine at M4 so the threads just stripped out under the pressure. So i used some nuts as spacers and fastened with some proud HT socket screws. Even so it got the job done. The middle was treppanned out on the lathe with a grooving tool, the lathe has to go alot slower than you might expect when you do this operation i found like 100-200rpm. It obviously bent in slightly once it was cut, so to clean up the rags i just used a very sharp knife tool to clean it up. Never trepanned thin material on the lathe before now so it was a new experience for me.
                                              The last job to do with this pulley was to drill or bore a larger hole into the pulley to fit the slightly bigger 3 phase motor from 14 to 19mm shaft. I would have to say, retrospectively i shouldve bored it but i was worried about breaking the tool on an interupted cut from cast iron on the keyway. So i used a 3/4" drill. The only problem with this is without using a "core" drill, which is like a 3 or 4 flute finishing drill, it would create a lobed hole, so it runs a little off centre but not enough to be a cause for worry. But thats the proper way to enlarge the bore with a drill.
                                              The keyway was interesting because i don't like creating them on the lathe because i cant lock the spindle. So i mainly use broaches, only trouble was i needed a 6 and i've only got a 5 as my biggest one. I don't have the money to spare on a new one so i managed to create a "stepped key" by milling away the last mm on a half and half key of different sizes! it does work, you just have to be sure of your measurements on the height of the key so it fits perfectly and not able to move inside it.
                                              So this is the setup on the inside now, back to its original state. I'm very happy with how it went and learnt a few new skills along the way, it sounds like a very dull job but there were moments where i needed to think about it a bit more. I'm glad to now have a variable speed motor with 6 positions at full torque! from 150rpm to 1600rpm.
                                              By the way i measured the RPM myself, i was lucky enough to obtain a smiths gauge from a farm that was chucking out it's old workshop gear. Good hint;it pays to collect tat and junk in this pursuit, you shall be goodly vindicated when it comes in handy!
                                              I created a chart to note all the new speeds, i'll get it laminated and stuck on the inside of the machine, hopefully if anyone ever takes over this machine from me, they wont need to do this themselves then. As the manual will no longer be correct for this.
                                              Edit: The machine is much quieter now, but i'm not really sure why. I only switched an aluminium pulley for an iron one! Maybe someone can tell me this.
                                              In the first photo it looks like the steel is slightly bent, but if you look closer it's actually my forehead in the reflection!
                                              Michael W
                                              Edited By Michael Walters on 23/08/2016 20:31:43
