Broaching
Broaching
Home › Forums › General Questions › Broaching
  • #365687
    Garry Coles
      @garrycoles69390
      Hi, I would like to make some keyways in 3 sizes of bores. 1/2" 5/8" and 3/4" for the traction engine I am building.
      The drawings say 5/32 keyway broach for the 1/2" bore and 3/16" keyway broach for the 5/8" & 3/4" bores. My first question is, to save money can I use 3/16" on all 3 bores. There is only a small difference between the two sizes. And who sells the broaches and collars for these sizes.
      Thanks
      Garry
      Edited By Garry Coles on 05/08/2018 13:24:06
      #26122
      Garry Coles
        @garrycoles69390
        #365688
        Thor 🇳🇴
          @thor
          Hi Garry,
          RDG has both 5/32" and 3/16" keyway broaches.
          Thor
          #365693
          Robin
            @robin
            I bought one of those in 3mm to connect a pulley I was making to the motor shaft.
            Being a complete broach beginner, I soon hit a snag…
            The spec said it could do a slot 30mm long, but the support collar and shim were considerably shorter than that.
            Due to the terrible forces involved, overhanging the support seemed like a terrible idea. So I stopped.
            Am I wrong?
            #365698
              No better to make a full length bush, I have quite a collection that I have made for flywheels. The length generally refers to the amount of shank above the last tooth so they will clear a 30mm thickness. ARC do extensions to push then further though I have not used the as a bit of flat bar seems to work for me.
              #365702
              Anonymous
                They seem a bit on the large size. I'd use 1/8" on the 1/2" and 5/8" shafts, and possibly 3/16" on the 3/4" shaft. But I suspect 1/8" will be fine for that too. To some extent it depends on the application.
                #365705
                  You could use the 3/16" one on the smaller sizes but leave out the shim which will give a similar depth of keyway to what the smaller size would have produced. It will depend a bit on how much metal there is around the keyways as to whether the bigger groove will weaken the part but TEs are usually quite hefty.
                  I got my 3/16" one from Steelmans
                  The other option is to just buy the small one and do the big one by planing on the lathe , did these 3/16" ones that way before I had the broach
                  #365736
                  Garry Coles
                    @garrycoles69390
                    Thanks for that info, I think I will now make up my own sleeves to go in the bores.
                    Thanks
                    Garry
                    #365954
                    John Reese
                      @johnreese12848
                      I, too am in favor of using the same broach for all shaft sizes. I agree with cutting a shallower keyway for the 1/2" size.
                      #365956
                      Nige
                        @nige81730
                        Jason: "Planing on the lathe" ??
                        #365958
                          Nige, Imagine a holder like this but with the tool ground square across like a parting tool on it's side.
                          Mounted in the toolpost like this
                          Then using the carrage handwheel move it through the hole in the part, slowly moving the cross slide towards you putting on cuts of 1 to 2 thou and you get a groove or keyway
                          #365959
                          Nige
                            @nige81730
                            Thanks Jason, got it 😊👍
                            #365963
                            I.M. OUTAHERE
                              @i-m-outahere
                              Has anyone come across a reference chart for making broach bushes ? It would be nice to be able to look up the dimensions of the slot required for each size broach and not have to fiddle around measuring the broach everytime i need to make a bush , this would also give you the thickness of the shim ( if needed ) . I think i remember seeing on by minuteman but it was for imperial sized broaches , i also use metric .
