Brazing copper
Brazing copper
Home › Forums › Materials › Brazing copper
  • #213475
    Ajohnw
      @ajohnw51620
      In case I ever do make a steam engine this is an area I wonder about. Boilers. Silver solder is usually used and I read that others can't be used due to sulphurous smoke off coal. There are numerous brazing alloys about that contain various mixes of silver, usually a lower % in in these, copper and phosphorous. Other things too at times
      I wonder how this fits in with propane fired boilers – no sulphur so why not?
      Edited By John W1 on 21/11/2015 15:57:03
      #29553
      Ajohnw
        @ajohnw51620
        #213482
        Keith Hale
          @keithhale68713
          There is no reason why a propane fired boiler cannot be put together using copper phosphorus alloys (CuP Alloys) that may or may not contain silver.
          Gas fired water heaters, central heating boilers are all made using these alloys.
          BUT
          DO NOT USE THEM ON COAL FIRED APPLICATIONS.
          a hot sulphur bearing atmosphere can cut through a copper phosphorus joint like a hot knife through butter!
          regards
          Keith
          #213492
          Ajohnw
            @ajohnw51620
            Thanks Keith. Be interesting to see if there are any other views.
            I was surprised just how many alloys are around when I looked. One aspect concerning choice might be max service temperature as this seems to vary. 20 bar, much higher than I would be interested in need water to be at well over 200C and then there is super heating the steam. The info I found seem to be more concerned about the minimum for refrigeration people.
              Thanks Keith,
              I have about a dozen CuP rods, and have never had the courage to use them.
              Bodgit Fixit and Run
                @bodgitfixitandrun
                Are these alloys safe to use with meths or fuel gels etc?
                Edited By Bodgit Fixit and Run on 21/11/2015 20:08:11
                #213530
                Ajohnw
                  @ajohnw51620
                  There are a lot of them. So which ones
                  Keith Hale
                    @keithhale68713
                    The most common alloys can be found here
                    http://www.cupalloys.co.uk/for-refrigeration-engineers/
                    They are readily available. Generally speaking
                    increasing silver content improves joint ductility
                    Increasing phosphorus content improves fluidity and reduces melting temperature
                    keith
                    Edited By CuP Alloys 1 on 22/11/2015 09:19:06
                  Home › Forums › Materials › Topics
