Brazing
Brazing
Home › Forums › General Questions › Brazing
  • #343058
    alan ord 2
      @alanord2
      Hi all, I need some advice. I have just finished brazing the steps and brackets for my Pansy 57XX loco and i need to clean up the carbon residue following the brazing. I have used a wire brush as far as possible but can't get into the corners. I am thinking about pickling them but not keen on using strong acids. I'm sure I have seen something mentioned in the past about using ordinary household products. I know that Cola can clean copper based items and possibly white vinegar or lemon juice. Can anybody suggest a method.
      Thanks, Alan.
      #25834
      alan ord 2
        @alanord2
        Clean up of steel brackets.
        #343059
        Thor 🇳🇴
          @thor
          Hi Alan,
          You can use citric acid for pickling, that is what I use. Takes a bit longer than sulfuric acid but is easy to obtain, if I have pickled steel I rinse in sodiumbicarbonate solution (to neutralize the acid) and then plain water.
          Thor
          #343062
          He Who Dares Wins
            @jameswilkinson3
            Safety pickle from cookson gold or maybe from Cousins. They are jewellers tools/ suppliers.
            #343085
            Samsaranda
              @samsaranda
              Alan, I use Citric Acid it takes longer than the stronger acids but is gentle in action, so gentle in fact that it’s safe on your skin, it’s only basically lemon juice but it does the job.
              Dave W
              #343093
              IanT
                @iant
                Alan,
                Look on eBay for "Citric Acid Food Grade" – 1Kg will last you a long time and costs about a fiver. Used in Indian cooking I believe… much (much) cheaper than the silly little boxes sold by Chemists.
                IanT
                Edited By IanT on 24/02/2018 21:39:17
                #343132
                Ian S C
                  @iansc
                  You can buy a box/packet of citric acid from the home brew shop, that's the cheapest, next place is the super market. If you need it by the hundred weight, an agricultural supply outlet.
                  Ian S C
                  #343144
                  Keith Hale
                    @keithhale68713
                    Hi Alan,
                    Carbon deposits – from brazing?
                    Where did they come from? Not the gas, nor silver solder nor the copper.
                    Or is it that the flux esidues are black? In this case neither citric acid nor sulphuric will help. A more likely explaination is that the flux has been heated too long or to too high a temperature and degraded.
                    Use a stiff wire brush or other mechanical means to clean things up. Inspect and test the joints.
                    Stop it happening again by using a longer life flux like HT5
                    Keith
                    #343146
                    Hevanscc
                      @hevanscc
                      Get a cheap kettle and packet of citric acid from Wilkinson. Add two tablespoons to kettle with water and boil. Pour boiling citric solution over components and leave to soak for 30 min. Then scrub with wire brush.
                      Hywel
                      #343285
                      alan ord 2
                        @alanord2
                        Hi Keith, thanks for your input and I can confirm is it is not The Cup Alloys purchased flux. The brazed joint is one side of the bracket. The whole bracket is discolored black and also has sooty deposits. I did use a wire brush on the accessible parts of the brackets but it is the corners of the steps I can't get at to clean before painting.
                        Alan.
                        #343289
                          Keith, I suspect Alan is talking about steel fabrications not the copper boiler. I also find that the steel takes on a black coating on the areas that are not fluxed but being happy to use an acid can get it to come off easily together with the HT5 flux.
                          This is the sort of black being talked about
                          Edited By JasonB on 26/02/2018 15:24:19
                          #343338
                          Weary
                            @weary
                            I use path or brick cleaner diluted in water to make a bath – add brick/path cleaner to water. Immerse blackened steel parts and leave until the blackened areas have flaked off. Some gentle abrasion/prodding, etc., will speed things up if desired. Parts are left with a matt grey finish that needs protection against rust immediately upon removal from the cleaning fluid.
                            In my experience there is no damage to the parts by leaving them too long (overnight) in the cleaning bath.
                            Phil
                            #344441
                            Zan
                              @zan
                              I use sulphuric acid. Very effective at removing the mess it comes off as very thin flakes. Also discovered by chance that it also removes the black mill scale found on thicker steel plate, a tiny rub with the finger will remove it with ease. Obviously take sensible precautions and rinse well. Essential to oil or prime the component straight away or it will quickly gains red colour!
                              Edited By Zan on 04/03/2018 20:57:33
