Boxford 280
Boxford 280
Home › Forums › Manual machine tools › Boxford 280
  • #492191
    Andy Sproule
      @andysproule22368
      Hi.on a boxford 280 at the headstock the direction lever for the lead screw and the speed levers for the lead screw does the machine have to be turned off to change them?The powerfeed leavers on the apron does the motor have to be turned off to change them?
      #14008
      Andy Sproule
        @andysproule22368
        #492255
        not done it yet
          @notdoneityet
          I would not be changing direction, or speeds, without the spindle at (or close to) stationary ( nor under power at the time). I always select the power feed mode before running the lathe, but engaging/disengaging is clearly carried out while the lathe is running. Not a Boxford, but the principle is the same.
          #492325
          Andy Sproule
            @andysproule22368
            Thanks for reply I have always stopped the machine but seen this guy doing it with the machine running and wondered what you guys thought?
            #492332
            Tim Stevens
              @timstevens64731
              Remember that on many machines the motor can be running but not driving anything – just like a car in neutral. Until you are clear about the full working of your Boxford it would be safer to stop the motor before waggling levers.
              Regards, Tim
              #492451
              Andy Sproule
                @andysproule22368
                Thanks for that Tim.
