Posted by Ron Laden on 18/10/2019 21:19:23:
I am a big fan of 638, […] For permanent fixing and retaining of parts 638 is the one I always use.
Likewise, Ron [for several decades]
But I maintain that ‘Bearing Fit’ is generally more appropriate for fitting bearings.
Edit: Quoting from the 641 Technical Data Sheet:
“LOCTITE® 641 is designed for the bonding of cylindrical fitting parts, particularly where disassembly is required for service operations. The product cures when confined in the absence of air between close fitting metal surfaces and prevents loosening and leakage from shock and vibration. Typical applications include retention of bearings onto shafts and into housings.”
Edited By Michael Gilligan on 18/10/2019 22:03:46
