Back to Imperial
Back to Imperial
Home › Forums › The Tea Room › Back to Imperial
Viewing 25 posts - 1 through 25 (of 85 total)
  • #563155
    David Noble
      @davidnoble71990
      Good job that the DRO on my mill can switch to imperial!!!
      David
      #36563
      David Noble
        @davidnoble71990
        #563160
        Clive Hartland
          @clivehartland94829
          But is it? most people now accept metric as it is widely used for wood and various sizes.
          Just learn to use both standards, all white goods give metric sizing. So a DRO ihas the switch between the two, good.
          #563165
          Oily Rag
            @oilyrag
            Regarding wood – I've never understood why it is sold in 1.2 mtr, 2.4 mtr lengths! I assume it is because it is impossible to divide by 3 in the 1, and 2 mtr lengths. Strange that they should decide on such an anomaly in a 10 base system.
            Likewise there is little uptake of the metric 400 grad divisions within a circle, although I have come across this weird division for circular definition in the Bosch engine management system for engine control to define crankshaft angularity – it caused mayhem before it was realised that a grad was not comparable to degrees.
            Martin
            #563167
            David Noble
              @davidnoble71990
              Ah, sorry, it's the news that we are to revert to imperial measurements.
              https://www.independent.co.uk/news/uk/politics/imperial-units-pounds-ounces-brexit-b1921732.html
              David
              #563168
              JA
                @ja
                Posted by Oily Rag on 17/09/2021 13:02:29:
                Martin
                1.2 mitres = 4 feet etc. It is easier to change the numbers than the actual dimensions.
                Changing back to imperial units. You must be joking and it is not even 1 April.
                JA
                #563170
                duncan webster 1
                  @duncanwebster1
                  Ridiculous, they will bring back empire day next. No wonder politicians are held in contempt
                  #563172
                  DMB
                    @dmb
                    Stuff Empire Day – Lord Beaverbrook hasn't been around for sometime……let's have a new Bank Holiday and call it Independence Day and thumb nose at the Brissels crowd.
                    #563173
                    Mick B1
                      @mickb1
                      I've still got the marks on the handle of the coffee spoon I pinched from my dad in 1973, where I set the magneto on my BSA A10 to 13/32" BTDC.
                      But my 2 sons and their families can't abide Imperial – they think it's deliberately arcane and difficult, which perhaps is part of its quirky charm.
                      #563179
                      Mike Poole
                        @mikepoole82104
                        The building industry is still a mess after all these years, a six foot fence panel is now 1800mm. Installing my new fence the concrete gravel boards were actually 6’ so the slotted concrete posts were too loose to contain an 1800mm panel, a couple of packing strips added to the panels made them fit.
                        #563180
                        Oily Rag
                          @oilyrag
                          Try getting a replacement 2' x 18" manhole cover!
                          When the galvanised steel one in my garden rotted away (taking with it into the sewer the wife's prize plant pot and contents) I was unable to buy a replacement. To get over this I had a mate with a bending machine make me up one in 2.5mm plate. The Builders Merchant told me the only way to replace these manhole covers was to fit the metric ones which meant rebuilding the top of the brickwork to suit the new cover and its frame. My mate now knocks out batches of imperial covers of 50 a time and they sell like hot cakes!
                          Martin
                          #563185
                          Mike E.
                            @mikee-85511
                            What I find is ridiculous is that plywood is sold as 4' x 8' sheets, and dry lining is sold in the slightly smaller metric size. It means that if you layout first floor joists for sheathing, then the layout will come up long for sheathing the ceilings below with dry lining; so you have a considerable waste loss of material when installing a ceiling.
                            #563189
                            Martin Connelly
                              @martinconnelly55370
                              Fiddling while Rome burns comes to mind. Are they going to redefine the pound as a fraction of a kilogram the same way the USA defines their inch as 25.4mm?
                              Martin C
                              Edited By Martin Connelly on 17/09/2021 16:05:38
                              #563190
                              Oily Rag
                                @oilyrag
                                Better still the Chinese tailors Inch!
                                I had a suit made in Shanghai and when they measured me up my waist was 30" and inside leg was 27" – I was delighted that my waist had shrunk but not so pleased about the loss of 5" height! On questioning the tailor it turned out their Inch is based on 30mm!!!!
                                Martin
                                #563192
                                Mick Henshall
                                  @mickhenshall99321
                                  I like imperial, I am 77, you deal with it
                                  Mick 😁
                                  #563195
                                  Mike Poole
                                    @mikepoole82104
                                    Posted by Martin Connelly on 17/09/2021 16:03:29:
                                    Martin C
                                    500g is widely called a pound across Europe, of course it’s a pfund in Germany and many countries have a word for it. I am sure that for foodstuffs it makes little difference as long as you aren’t supplied with 453.6g and charged for 500g.
                                    #563199
                                    mechman48
                                      @mechman48
                                      ..I am sure that for foodstuffs it makes little difference as long as you aren’t supplied with 453.6g and charged for 500g'
                                      Are you sure your not; & by the way I've not seen anything on sale with a weight of 453.6g it's always 100g, 450g, 500g, 1kg increments.
                                      George.
                                      #563209
                                      KWIL
                                        @kwil
                                        Plywood being yesterday's product is no doubt still made on imperial sized machinery?
                                        #563210
                                        duncan webster 1
                                          @duncanwebster1
                                          This is going to degenerate into a stand off between die hard imperialists and rational people who can see beyond the ends of their noses
                                          #563213
                                          john halfpenny
                                            @johnhalfpenny52803
                                            But the government will use this to divert the public from real issues, like what is the care home policy ? Can I have a chocolate biscuit please matron.
                                            #563219
                                            Spurry
                                              @spurry
                                              What's the betting/odds that petrol will not be sold by the gallon? £6.91 for a gallon – you must be joking!
                                              #563220
                                              Bazyle
                                                @bazyle
                                                I recall the 8ft (2400) length of wood was a standard supplied by the Scandinavians and called a 'deal' and as such sold throughout Europe starting hundreds of years ago. Hence houses everywhere tend to be built using submultiples of it, regardless of units used. 16in stud spacing has never been a 'round' figure that a mathematician might choose, let alone the 14+ a smidge for the noggin. It is only recently that site carpenters apart from the foreman could afford a rule anyway. As for plasterboard not fitting, that's probably 'cos some dumb ass graduate engineer who had never been near a building site wanted to make it a nice 'round' figure.
                                                #563231
                                                Peter G. Shaw
                                                  @peterg-shaw75338
                                                  I'm 78, so older than Mick above, and I much prefer metric. Indeed, I find metric linear measurements much more understandable than imperial. Capacity measurements & weights are someway behing linear measurements, but slowly I'm getting there, and I don't want to go back. Indeed, the whole concept of imperial I find to be a recipe for disaster. Think pennies, shillings, pounds, what a rotten system requiring an in depth knowledge of the 12 times tables and the 20 times table. 100p to the pound is so much easier. Similarly, ounces/pounds/stones/hundredweights/ton's etc. requiring a knowledge of 16's, 14's, etc.
                                                  So, as far as I am concerned, although brought up as an imperial child, and am to an extent struggling with the visualization of the various metric quantities, I am slowly becoming au fait with it, indeed in some instances I already do think metric in preference to imperial.
                                                  It will be a bad day if we have to revert to imperial.
                                                  Peter G. Shaw
                                                  #563236
                                                  Brian G
                                                    @briang
                                                    I bet shopkeepers would love the idea of selling a 2lb bag of sugar for the same price as a kilo.
                                                    Brian G
                                                    #563243
                                                    Bill Dawes
                                                      @billdawes
                                                      I'm 79, 80 in a couple of months, doing model engineering has made me think back to my apprentice days on the shop floor and drawing office and realise now how ridiculous trying to use dimensions such as 37/64" was. Nostalgia apart, metric is far more logical.
                                                      I do however after so many years have the ability to be able to quickly convert in my head approximations of imperial to metric and vice versa. The industrial fan industry I (still) work in deals with markets all over the world and mechanical, chemical, electrical engineers etc. all with favourite units such as cubic feet per minute, m3/hr, inches water gauge, pascal, millibar ad infinitum. There are times however when the metric system falls down, I can readily convert all these but I have always said the bloke that invented inches water gauge new what he was doing, you can see a column of water, how do you visualize a pascal? Easy, convert it to inches water gauge!!
                                                      Bill D
