Are these change gears?
Home › Forums › General Questions › Are these change gears?
  • #360417
    Steveg
      @steveg18231
      These came with my myford ML4 and being new to advanced lathing I’m a little unsure if there change gears or not…advice appreciated.
      https://imageshack.com/i/poPkaA04j
      I want to put them on eBay so need confirmation.
      I have various sized faceplates,3 jaw and 4 jaw chucks,rest steady that are all surplus to my requirements
      Edited By Steveg on 02/07/2018 17:37:43
      #26065
      Steveg
        @steveg18231
        #360418
        Tony Pratt 1
          @tonypratt1
          Yes they are change gears but it looks like you have already made your mind up?laugh
          Tony
          #360420
          Steveg
            @steveg18231
            Posted by Tony Pratt 1 on 02/07/2018 17:43:59:
            Tony
            Being unsure I needed to just ask
            Thanks tonyyes
            #360425
            Brian Wood
              @brianwood45127
              Not only are they change gears, but they are specifically for Myford ML1-4 lathes which had a linking pin to drive a compound gear set up; you even have the pin shown in one of them . ML7 gears are linked by a keyway in the bore.
              To help a prospective buyer the need to ask, list the tooth count as well
              #360429
              Steveg
                @steveg18231
                Posted by Brian Wood on 02/07/2018 18:14:07:
                Thanks Brian much appreciated.they are on eBay with a starting bud of £20 as value I have no idea!
                #360433
                Brian Wood
                  @brianwood45127
                  Steve,
                  Your 3 jaw chuck is a Crown, they were often supplied with Myford ML1 and 2 lathes.
                  Prospective buyers will want to know if both inside and outside jaws are supplied; the mandrel thread fitting size and tpi of that thread. For those lathes I believe these were frequently 7/8 inch x 9 tpi but measure yours to be sure.
                  #360544
                  Hopper
                    @hopper
                    I'd be interested in buying the one 60-tooth gear on its own if you don't sell the lot on eBay.
                    #360545
                    Ian S C
                      @iansc
                      Just make sure you don't sell today what you need tomorrow, it will cost you an arm and a leg. Do you really want to sell for example the steady. A full range of tooling, change gears etc., add much to the value of the lathe.
                      Ian S C
                      #360553
                      Steveg
                        @steveg18231
                        Posted by Hopper on 03/07/2018 11:51:28:
                        I wouldn’t have a clue what they are worth…send me a message?
                        #360554
                        Steveg
                          @steveg18231
                          Posted by Ian S C on 03/07/2018 12:00:17:
                          Ian S C
                          I know I won’t need them Ian and don’t plan on selling the lathe.
                          #360562
                          Hopper
                            @hopper
                            Posted by Steveg on 03/07/2018 12:24:50:
                            Thanks. PM Sent.
                            #360704
                            Ian S C
                              @iansc
                              That's good, you will be able to fund some tooling, and metal to work on. With model engineering all donations gladly accepted.
                              Ian S C
