An “Omega” spring to keep Parallels in place
Home › Forums › Hints And Tips for model engineers › An “Omega” spring to keep Parallels in place
  • #65356
    chris stephens
      @chrisstephens63393
      Hi Guys,
      Hers’s something for all you chaps who use parallels in your milling vice and have difficulty keeping them in place. Or should I say, here’s something for all you guys not blessed with three hands.
      The spring is made of Phosphor Bronze, is about 4thou thick and the shape I find best is rather like a Greek “Omega” . I hope you can see from the photo how it is used. They take seconds to make but can save “hours of harmless fun” as the advert used to say.
      I have seen people use coil springs to do the same job but obviously you can only crush them so far, with the Omega spring you can crush it right down to virtually nothing and it will still spring back to shape.
      I am sure the idea is not new, but I had not come across it before and I would think that some of you had not either. I hope some of you find the idea helpful.
      chriStephens
      Edited By chris stephens on 11/03/2011 19:23:50
      #30320
      chris stephens
        @chrisstephens63393
        A simple little device that might help you.
        #65358
          One of those little bits of expanded polystyrene packaging you get 1000s of in a box also does the trick and it won’t catch a drill bit as you break through right above a metal spring.
          Jason
          Edited By JasonB on 11/03/2011 20:17:18
          #65362
          NJH
            @njh
            That’s a good idea. Has anyone tried these “wavey” parallels though?
            Norman
            #65367
            ady
              @ady
              I tend to use toolsteel bits and old bearings as parallels.
              #65370
              Terryd
                @terryd72465
                Hi All,
                A guy on another forum recommends using that thin foamed flexible plastic sheet often used in packaging, it feels a bit waxy if you know the stuff. Thin foam food packages suitably washed can be cut up to do the same job of keeping parallels in order
                Terry
                #65379
                clive swinney
                  @cliveswinney28133
                  Hi all
                  I use flexible magnetic self adhesive strip attatched to all my parallels. It works for me.
                  #65382
                  KWIL
                    @kwil
                    Norman, I have used the wavy parallels, they are very good when your other parallels are too wide. They will take a set if you crush them too far and go easy on the mallet!
                    #65390
                    NJH
                      @njh
                      Hi KWIL
                      Thanks – I will add a set to my ” Wish List” then.
                      Norman
