Aircraft General Discussion
Home Forums The Tea Room Aircraft General Discussion
Viewing 25 posts - 976 through 1,000 (of 2,013 total)
  • #280980
    David Colwill
      @davidcolwill19261
      Posted by Mike Poole on 28/01/2017 12:56:58:
      A couple of pictures of Gibralter in March 1942, the aircraft is a Beaufort and the view is from the side hatch where a K gun was temporarily mounted, must have been a bit draughty. My father was the pilot and they were en route to Ceylon, quite an adventure for a 22 year old.
      I can't imagine having to take those kind of risks / responsibilities at 22 years old. Much respect to your Dad.
      David.
      John Olsen
        @johnolsen79199
        It would be more likely to be the rotor that would damage a glider. Quite often, under the lenticular wave cloud there is a rotor cloud much closer to the ground. What happens is that the rushes over the mountain range, down on the leeward side and then up again into the first wave, forming the lenticular cloud up high. Underneath a horizontal rotor can form, with wind close to the ground actually going in the opposite direction to the wind at altitude. Sometimes wisps of cloud can be seen in the rotor, and they can be seen to be rotating quite rapidly.
        I grew up in Masterton, in the Wairarapa, which is a valley in the lee of the Tararua ranges. The ranges lie across the prevailing northwest wind, so often provide good wave conditions. Masterton is quite fortuitously in quite a good position as it can be experiencing a gentle wind from the east when the rest of the valley is experiencing a strong norwester.
        The wave conditions can prevail for the length of the ranges in the North Island from East Cape to Cook Strait, and across the strait for the full length of the South Island. So some very long glider flights have been made. Often more than one wave cloud can be seen, eg a second wave forms downwind of the first. The Tararua ranges are only around 5000 feet high, but the wave cloud can be at around 20,000 feet or so.
        Anonymous
          Posted by John Olsen on 29/01/2017 11:05:43:
          I'd agreed. The down of a wave is as smooth as the up, except that the glider is imitating a house brick. On the other hand rotor can be as rough as it comes. On the ground it can be dead calm under the rotor, whereas at a few hundred feet it is all hell let loose. At Aboyne, in a southerly, I've seen the windsock point to all four cardinal points, followed by straight up.
          I had to look up the Sheffield incident – February 1962. It was part of severe westerly gales across a large part of the UK, over a couple of days. However, at least one report mentions a resonant lee wave effect. I think it is most likely that the damage was caused by rotor that reached down to the ground, rather than the wave per se.
          Sometimes the only way to get into wave from a hill or winch launch is to climb in the rotor first; exciting stuff. Here's a picture of what happens when you get in the down of the wave and don't twig what is going on. embarrassed You end up in an unsuitable field, but the only one I could reach:
          This is a picture of a roll cloud:
          It was taken in North Wales, looking north towards the coast. The gliding site is the triangular field lower centre. The rotor worked rather well and could be soared almost like a ridge. The wave was odd that day too. The picture was taken after a climb to 20000 feet over Snowdon, having jumped foward two 'bars'. There were no lenticular clouds, just hazy blue sky. Unusually for high wave the climb rates were weak. I didn't see anything much above 150ft/min. The approach into the gliding club was exciting; the glider fell out of the sky at 200 feet and I ended up looking at the ground through my feet. smile o
          #283830
            I think this qualifies for inclusion in this thread:
            http://www.darpa.mil/news-events/2017-02-06
            Demonstration of SideArm
              Ooops … double post
              Edited By Michael Gilligan on 12/02/2017 18:03:03
              #283865
              Ian Abbott
                @ianabbott31222
                I do like the implication that only the US Navy has the technology and skill to launch and recover aircraft from a floating platform, y'know like an aircraft carrier.
                That said, something that caught my attention was that unless the moving object just happens to be traveling along a path that might coincide with some stationary structure, all this technology 'aint worth spit, as they apparently say out west. It's like the fielder standing six feet to one side of where the ball's traveling; the thing is heading straight for the boundary.
                Ian
                #287479
                Anonymous
                  Never mind cuckoos I've just watched the first Spitfire of the year doing aerobatics over the bungalow. Quite a work out; apart from the normal loops and rolls there were high speed dives, and more unusually a stall and one turn of a spin.
                  On another matter I note that the AAIB final report on the Hawker Hunter crash at Shoreham in 2015 was published last week. I haven't read all of it yet, as it's over 400 pages.
                  #287516
                    Posted by Ian Abbott on 12/02/2017 21:10:40:
                    That said, something that caught my attention was that unless the moving object just happens to be traveling along a path that might coincide with some stationary structure < etc. >
                    dont know
                    The demonstration involved catching a Lockeed Martin Fury … which would be 'returning home' rather than just happening to be traveling along a path that might coincide with some stationary structure.
                    ega
                      @ega
                      Microsoft Flight Simulator ver 5 for MS-DOS – Pilot's Handbook (284pp)
                      Does anyone want this period piece (complete with plan of Orly runway)?
                      Free to collect or sent for postage (504 gms net)
                      Edited By ega on 19/03/2017 16:08:26
                      #289551
                      Danny M2Z
                        @dannym2z
                        I often fly to Sydney from Albury.
                        Nice to know that the SAAB's work ok when a bit falls off. **LINK**
                        * Danny M *
                        #289586
                        Ian S C
                          @iansc
                          Saw the Saab on TV news, bit of a bother, reminds me of an incident in the early 1960s, one of our pilots radioed in to New Plymouth that his engine was "missing". The tower suggested he try switching the mags, the pilot didn't think this would work, as the engine was missing in that it had fallen out of the aircraft. The aircraft a Cessna 185 was landed with little damage on some clear land.
                          Ian S C
                          #289590
                          Speedy Builder5
                            @speedybuilder5
                            Not very comforting:-
                            "Some things just can’t be seen,” Mr Smith said. “Ninety-nine-point-nine per cent of the time something like this doesn't happen.”
                            That means that 1 in 1,000 flights have a serious incident. I think Mr Smith doesn't understand statistics!
                            BobH
                            #289594
                            Edward Crouch
                              @edwardcrouch25793
                              Civil airworthiness requirements are 1*10^-9 catastrophic failures per fleet flying hour. MIL is 10^-6.
                              So, 1*10^9 hours is the fleet safe life, divide by fleet numbers, divide by hours flown per year, gives you a rough guess at the maximum fleet life in years from that perspective. There are many many many other considerations though, dual redundant load paths, redundant systems, preventative maintenance (particularly D-check) fail safe and rip-stop construction all play a major role.
                              #290341
                              Mike Poole
                                @mikepoole82104
                                Martin Bakers Meteor WL419 was just out for a fly round Chalgrove airfield, haven't seen it for a while. Flew over my house but grabbed camera too late, wind blowing our way so good whiff of kerosene after he landed.
                                #290476
                                Ian S C
                                  @iansc
                                  Luv the smell of Avtur. Good to hear that there is still a Meteor airworthy.
                                  Ian S C
                                  #290484
                                  Mike Poole
                                    @mikepoole82104
                                    Martin Baker (now Lockheed Martin) still have two Meteors serviceable for ejector seat testing. The testing program seems a lot quieter in the last few years so most flights are probably just to keep them in good working order.
                                    #290490
                                    JA
                                      @ja
                                      Posted by Mike Poole on 25/03/2017 13:48:32:
                                      Two different firms (unless they have merged very recently). The Martin in Lockheed Martin was the old US aircraft company that made the Canberra bomber under licence, the B57 powered by J65s (A.S. Sapphire also built under licence).
                                      JA
                                      #290504
                                      martin perman 1
                                        @martinperman1
                                        Just had a look at Martin Bakers web site, still a british company making ejectors seats.
                                        Martin P
                                        #290506
                                        Richard S2
                                          @richards2
                                          These 2 Starter Cartridge Cases had spent much of their life on a Mantelpiece in my parents home. As a child, I was always fascinated with the shine and colour, so had the job of cleaning them and other Brasses
                                          dsc01420.jpg.
                                          My father told me he had saved them from the days of his career with Hawkers at Dunsfold. He told me they were used on one of the 2 Avon engined F1 Hunters which were going through further development into 1953-
                                          As there is no value, or other purpose to them, I decided to make use of them and incorporate both as Fuel Tanks for a 1954 Villiers powered Water Pump project. Also have 2 x 30mm Cannon Cartridges from the Aden Cannon Pack trial firings. which I'll try and incorporate.
                                          Bit more cleaning to do inside first. Just have to find a use in the Workshop for the pair of Hinges believed to be from a Gloster Meteor Elevator….any takers for varification if I stick an image up on here?.
                                          He was obviously not allowed to obtain a memento of his development work on the P1127/ Kestrel, but I was introduced to Bill Bedford (when I was 10) who gave me his Autograph……a start to my eventual career of obtaining Autographs from Thousands of Pilots………on Weight and Balance Loadsheets ! smiley
                                          #290510
                                            Posted by Richard S2 on 25/03/2017 17:21:45:my eventual career of obtaining Autographs from Thousands of Pilots………on Weight and Balance Loadsheets ! smiley
                                            One of my steplads used to do those for DHL mail flights out of Nottingham.
                                            He must have been OK at it because he was never on the sharp end of a pilot's wrath when they aren't right!
                                            Mike Poole
                                              @mikepoole82104
                                              Posted by JA on 25/03/2017 14:44:42:
                                              JA
                                              Foot firmly in mouth there! They must be one of the few leading engineering companies to still be British. Very glad to be wrong.
                                              #291629
                                              Ian S C
                                                @iansc
                                                Today is the 80th anniversary of the founding of the RNZAF, over the last few years I have wondered about the date, because these days it seems like a long distance (in time) April fools joke.
                                                Ian S C
                                                #291645
                                                Adrian Giles
                                                  @adriangiles39248
                                                  Seeing Danny M2Z's post about the SAAB problems, reminded me of the Yootoob vid of Clarke & Dawe "The front fell off". Cracks me up every time, especially the ending with the ministerial car !
                                                  Aussie humour, brilliant!
                                                  Edited By Adrian Giles on 01/04/2017 14:21:53
                                                  Edited By Adrian Giles on 01/04/2017 14:28:22
                                                  #291664
                                                  NJH
                                                    @njh
                                                    Well not aircraft I know but I do have a SAAB car – bought new in 1968 – and it is still a pleasure to drive – what is more it still looks good! Prior to this one I had an old style SAAB 900 – built like a tank but it developed an engine problem which nobody seemed able to fix.
                                                    I will steer clear of buying a SAAB aircraft then! wink
                                                    Norman
                                                    #291689
                                                    Cornish Jack
                                                      @cornishjack
                                                      Norman – if yours was a 99, I bought similar in 73 in Cyprus. Drove it back to Uk and also had engine problems. The engine in the 99 was a badged Triumph Toledo with an ali crankcase and (from memory) was VERY fussy about the anti- ice additive used. When mine eventually went for 'fixing', the cylinder head was attached to an overhead hoist and the whole car hung on it for four days before it started to release!! As you say, built like the proverbial but Triumph did them no favours!!
                                                      rgds
                                                      Bill
