A month ago I became the owner of an Acorn shaper and am currently restoring it to its former glory. Luckily once I cleaned the grime off and removed the multiple layers of paint (all graduations, gib screws and even some of the ways and feed screws were lathered in paint!), I discovered it to be in fairly good condition with very little obvious wear.
I am consulting the Atlas manual in the rebuild and see that the specified lubrication is oil via oil cups for the Atlas machines. My Acorn however does not have a single oil cup, but instead is equipped with what I initially thought were grease nipples. However when I stripped the machine I could find no evidence that grease was used and realise that these were oiler nipples like the Myford lathes have.
Now my question is were the Acorn machines factory fitted with oil nipples, or is this likely to have been a later conversion?
My thought is that possibly because the Acorn was the British variant of the Atlas, it may have been factory fitted with oil nipples but I'm not sure as I can find very little info on Acorn shapers. Any Acorn owners out there that could shed some light on this? Thanks in advance
