A New Fastener
A New Fastener
Home › Forums › The Tea Room › A New Fastener
Viewing 25 posts - 1 through 25 (of 25 total)
  • #829939
    Vic
      @vic
      On the way for future BMW’s?
      IMG_7120
      #829941
      Andrew Tinsley
        @andrewtinsley63637
        Maybe BMW could reinvent the wheel as well.
        Andrew.
        #829944
        vintagengineer
          @vintagengineer
          Renault tried this with a five sided bolt. Most mechanics replaced them with a normal hex after removing them .
          #829950
          noel shelley
            @noelshelley55608
            BMW have been making life difficult for motorist and riding mechanics for a long time. Bolts round the bell house just normal ones, EXCEPT the 2 right at the top where it’s difficult to see, their torx, this was 30 years ago when many had never seen such a thing, let alone have the right size. Do they have a standard thread or is that special too so you can’t change them ?    Noel.
            #829959
            Vic
              @vic
              I think one of these Japanese motorcycle manufacturers did this as well?
              Someone just manufactured penta sockets. 😊
              IMG_7122
              #829968
                Nice to see they are flank-drive, Vic
                John Haine
                  @johnhaine32865
                  We have speed sign brackets in our village on which to mount Movable Vehicle Activated Signs where the bracket clamping to the posts uses jubilee clips tightened with a 7 sided Socket Head screw.
                  #829994
                  bernard towers
                    @bernardtowers37738
                    Lets hope they have only filed the patent cos if they intend to use it we are all in trouble.
                    #830047
                    howardb
                      @howardb
                      It’s no bother, the 7 sided toolbits are available.
                      https://www.reidbrothersuk.com/tamtorque-tool-bit
                      #830057
                      Vic
                        @vic
                        You can buy 5 sided as well.
                        IMG_7127
                        #830068
                        John MC
                          @johnmc39344
                          I first came across Torx headed fastener on BMW motorcycles, then they seemed to appear everywhere I looked!
                          The way they carry the tightening/undoing torque better than an “Allen” type socket, supposedly.  The problem is that, in the smaller sizes, is that a one size too small key (wrench) will engage the splines, just.  One may get away with it but the usual result was to damage the screw socket.
                          A BMW mechanic told me one job they frequently did was to remove damaged screws because of the above, he hated the the b****y things.
                          I can see the same happening with the new fastener head?
                          Perhaps it could be a way of invalidating a guarantee…
                          #830308
                          howardb
                            @howardb
                            Scottish Car Clan.
                            #830313
                            Nigel Graham 2
                              @nigelgraham2
                              He could have said that lot in two minutes, but he doesn’t suggest a practical solution or ask if the appropriate screw-drivers will be available in Halfords and the like.
                              What encourages the like of BMW of course is that expensive cars like theirs are affordable mainly only to those who can buy new and have all the servicing and repairs done by the “approved” garages – and would likely barely know which end of a spanner to hold anyway.
                              Looking at the photo, it might not be too difficult for the likes of us with workshops to make our own screw-drivers for the things. The walls of the sockets appear vertical. It might be feasible even to use a cutting-disc to make a slot in the end of an old screw-driver to clear the central web with enough room to engage the flats.
                              I have noted the irony in the assorted fancy socket-bits and screwdrivers now being sold in many shops, labelled for “security” screws!
                              Just occurred to me… are the threads on these money-grabbing fasteners ISO-Standard pitches or specials known only unto BMW, to hinder or prevent replacing them with proper ones?
                              At one point in the video the speaker referred to BMW wanting tighter laws on DIY car maintenance. Some years ago the big European manufacturers were lobbying for even worse: a law that all repairs and servicing must be done only by their main or their “approved” garages.
                              #830320
                                If they don’t want others removing the screws then surely they should take out a patent on the tool as well as the screw then they could stop aftermarket tools being sold.
                                My brother was a BMW Meistertechniker (master technician) and every dealer is required to employ at least one of these as they get more extensive BMW training and are the first to be trained on new models etc. A large part of their work coming into the workshop was putting right work done by independents and home fiddlers who either could not solve the problem, fitted unnecessary parts or mucked up other items trying to do so. They also knew what was the cause of likely problems so were able to deal with it rather than trying to find a known to them fault.
                                Typical example was one of the 3-series cars that could suffer from fuel starvation. The backstreet fixers would start fitting new pumps, injectors etc and not cure the problem. Yet the trained BMW technicians know that the fuel line that passed under the rear seat could get slightly dislodges and squashed so knew the quick and simple fix. You may pay higher prices but someone has to cover the 3 months a year my brother was getting trained and not bringing in money to the dealership.
                                So is it such a bad idea?
                                #830326
                                Nicholas Farr
                                  @nicholasfarr14254
                                  Hi, but not all BMW technicians are that good. In my last day job, one of the office chaps had a sensor which snapped off his catalytic converter, the technician at the local BMW service centre said that the converter had to be replaced with a new one, so he brought it into the workshop and asked me if I could get the offending bit out of the threaded hole, so a new sensor could be fitted, which I did, but it was a tricky job, and it saved him a tidy bit of money for a replacement converter. Needless to say the BMW technician hadn’t got a clue as to how to save the convertor from the scrappy.
                                  Regards Nick.
                                  #830332
                                  Dave S
                                    @daves59043
                                    Those will undo just fine with a cold chisel tangentially around the edge.
                                    The sheer off security bolts that used to be fitted to various BL cars did.
                                    noel shelley
                                      @noelshelley55608
                                      Who in their right mind would put the aluminium bodied high pressure fuel pump in a foam rubber  band,in a steel bracket and site it just ahead of the rear wheel, open to the elements. YEP ! BMW.
                                      I didn’t need 3 months in Bavaria or be a Meistertechniker to see the puddle of petrol or understand WHY it had corroded through .
                                      The spark eroder would take less than 10 mins to make a key in good steel.  Noel.
                                      #830344
                                      Andy Stopford
                                        @andystopford50521
                                        An even better idea would be to fix the fuel line properly so it doesn’t get squashed
                                        #830346
                                        Robert Atkinson 2
                                          @robertatkinson2
                                          Has anyone else considered that this whole thing could be a AI generated hoax or a publicity stunt by BMW?
                                          I can’t find any reference to an actual patent or similar.
                                          Robert.
                                          #830351
                                          Fulmen
                                            @fulmen
                                            #830354
                                            not done it yet
                                              @notdoneityet
                                              Typical BMW.  Trying to encourage/enforce dealership repairs.
                                              #830356
                                              Robert Atkinson 2
                                                @robertatkinson2
                                                It’s just an application. It could still be a publicity stunt. Or someone having a target to file for a certain number of patents in order to get their bonus…
                                                Robert.
                                                #830361
                                                Nigel Graham 2
                                                  @nigelgraham2
                                                  I see the problem with using special fasteners and similar tricks is not in preventing well-meaning owners causing more damage than the original failure. That was likely always a fairly minor one anyway.
                                                  Rather, it is making it harder and costlier for repairing breakdowns, perhaps far from home, even by professional garages let alone at the roadside.
                                                  The manufacturers’ own garages or so-called “approved” dealers are likely to be few and far between – and I would not trust them to ask a fair fee, notwithstanding that I do know the nature of  “labour charges” or “overheads” before any profit element. I cost my employers’ customers a lot more than even my gross pay!
                                                  Though I do know there are bad as well as good independent garages……
                                                  My sister took her preserved motor-caravan to a local garage our family had used for decades under its original, very reliable ownership.. The new garage owners managed to put a huge scratch along the side, and lose the dipstick and its tube. They tried to fob her off with a second-hand dipstick from an unknown car! She told then firmly that would not read correctly, but she still had to order a new one through an Owners’ Club.
                                                  Then last week I needed new suspension-rubbers for my car’s silencer. In theory I ought be able to fit them myself, but not safely or easily at the kerbside in a narrow street. It’s a former ‘Motability’ car so is modified… so Kwikfit said NO. Not “standard”, and Head Office does not allow branch mechanics the skill and initiative to solve such problems.  However, the manager referred me to a small garage nearby.
                                                  The chap there said he could tack-weld the exhaust to the chassis!
                                                  “I don’t like to tell you your profession,” I said, “but is that wise, with the engine mounted so it can rock?”
                                                  Fortunately he saw my point, and though I had to await their delivery it did not take long for someone else to fit the new rubber mounts.
                                                  #830365
                                                  Howard Lewis
                                                    @howardlewis46836
                                                    I found a Japanese fuel injection pump, with the elements secured to to the body by bolts with 5 sided heads.
                                                    There are probably rwo reasons for using “strange” fasteners.
                                                    One is to keep servicing within the manufacturer’s network (Understandable)
                                                    Second is to make life difficult for ” amateurs” (Non manufacturers trained operatives) – again to keep work within the network where possible, and IF the specialised tools are sold, to maximise profit to the dealership and manufacturer .
                                                    (The governor shaft on the Bosch EPVE Fuel Injection pump was secured by two three sided fixings). Guess the only source of supply, and cost of a socket?
                                                    Similarly, it was not unknown for Delivery Valve bodes to be splined, rather than hexagon, on injection pumps by some manufacturers.
                                                    Cylinder head bolts, among other fasteners are often tightened just into yield.
                                                    One manufacturer insist that they are replaced, once removed,.
                                                    When we adopted yield tightening, we proved that the fasteners could be reused, more than once. This reduced the cost of ownership for our customers in industrial, construction ad agricultural fields. It also reduced the incidence of head gasket failures to almost zero.
                                                    Did this benefit the manufacturer? DEFINITELY! Almost no problems in house or warranty claims; so a win – win
                                                    #830486
                                                    martin haysom
                                                      @martinhaysom48469
                                                      Regards Nick.
                                                      could be management would not allow him/her to repair it
