electrical socket screw problem
Home Forums General Questions electrical socket screw problem
  • #863285
    Buffer
      @buffer
      Hi
      I have just taken the screws out of an old looking MK twin electrical socket and now I cant get them back in.  The ends of the screws are all worn away and wont pull up tight.
      It seems as though the old back box may have 4ba threads and someone has forced m3.5×0.6 screws in which is why they are chewed up.
      I have tried new 3.5mm screws and they also get messed up and instantly tight so no hope there so my question is.  Do you think I could just tap the 4ba back box 3.5?  Or is it just wishful thinking?  Maybe I can tap 4ba onto a 3.5mm screw.
      The other thing I’m thinking is to solder a piece of rod onto a shortened screw and thread the extension piece 4ba.
      I don’t really want to change the box as it would involve knackering the plaster on the wall.
      Any ideas or advice is greatly appreciated especially if you’ve also had this problem.  Thanks
      #863292
      Bill Phinn
        @billphinn90025
        What sort of female thread arrangement is inside the back box? Those thin bendy metal tabs or a brass insert inside the plastic moulding?
        Assuming it’s the first, and you’ve got a supply of replacement M3.5 screws of the right length, you can use what’s called a back box saver. It’s a T nut basically.
        For mangled examples of the second type, some trickery with JB Weld will be necessary, unless someone has got a better solution.
        #863300
        Wingo
          @wingo
          Hi, How long are are the 4BA screws required?
          I do have some ‘in stock’ from time gone by…
          I might have what you would need.
          Michael
          #863301
          Buffer
            @buffer
            Thanks Bill I had not seen a back box saver I might need that.  Its a thin bent tab no plastic anywhere.  I have just drilled into the end of a 4ba cap screw and silver soldered it to a turned down 3,5mm screw.  I’m hoping this will work first but thanks again.
            #863303
            Buffer
              @buffer
              Michael they are 45mm long countersunk slot head.
              I’ll try this first and as long as the tabs are knackered it should work.  I’ll try running a tap down the hole first.
              #863318
              Bill Phinn
                @billphinn90025
                Have you established what pitch/standard the female thread is though, i.e, that it’s definitely 4ba? Whichever it is, it sounds like the female thread may be compromised, so some re-chasing or more drastic thread repair may be necessary before you can just thread in your Frankenstein screw.
                #863320
                Buffer
                  @buffer
                  Bill I haven’t established it but a 3.5mm won’t go in.  I did google it and the old standard is apparently 4ba so I thought i’d try that first.  I don’t have a 3.5mm tap but I do have 4ba so I might just see if that will go in if the Frankenstein screw won’t.  Annoying thing is the socket is a 1hr 10 min drive away so I’m trying to cove every option.
                  #863323
                    From what I have read here, the best option must surely be to purchase a 3.5mm tap.
                    DC31k
                      @dc31k
                      Would it be useful to write down the diameter and pitch of both threads on a piece of paper?
                      Then look at the numbers and think about the implications, keeping in mind how the female thread is formed, how deep that thread is and the likely tolerances applied to it for the application.
                      #863331
                      Wink Hackman
                        @winkhackman25989
                        Mangled backbox threads are a daily occurrence for sparkies. If they’re undersize then it’s not hard to fix. One of these should sort you out:
                        https://www.screwfix.com/p/c-k-re-threading-tool-m3-5-x-0-6mm/59312
