Fobco or a Clarke CMD 1225 milling capabilities? or other recommendations?
Home Forums Workshop Tools and Tooling Fobco or a Clarke CMD 1225 milling capabilities? or other recommendations?
  • #811218
    jacobsmess
      @jacobsmess
      I’m looking for advice on buying a first mill.
      I want to mill some splines on a hardened steel shaft to begin, then onto other more basic stuff… possibly.
      I’ve heard the Fobco drills were designed for some light milling capabilities does anyone have , other options are a clarke CMD1225.
      Any recommendations on suitable units for a tight budget (<£350) and a small workshop?
      Clive Brown 1
        @clivebrown1
        Fobco produced a specially modified version of the “Star” drill for light milling, but the much more common ordinary version is not suitable at all.
        #811238
        howardb
          @howardb
          “I want to mill some splines on a hardened steel shaft to begin, then onto other more basic stuff… possibly”
          Milling splines on a hardened steel shaft is not a normal operation.
          Normal would be to mill the splines on the shaft in the soft/annealed condition and then harden it.
          The clarke CMD1225 is a good basic mill/drill which will machine to quite close limits with an experienced operator. I had a similar machine in a workshop in the 90’s just to do odd jobs.
          3 mt spindle, 750 watt motor, belt drive, big heavy machine for what it is – close on 200 kg.
          But – it’s got a round column so you lose the dimensional accuracy if you crank the powerhead up.
          If you can find one for £350 you will be lucky, and Machine Mart & Sealey don’t seem to list it any more.
          Best of luck.
          #811252
          jacobsmess
            @jacobsmess
            Thanks Howard. Yes I’ve come to that conclusion, I will have the shafts annealed and hardened after milling. Thats good to hear that the Clarke machine is capable, I’ll look to pick that up.
            Thanks Clive, the description on lathes.co.uk suggests for the fobco drills they are capable of light milling. The universal had the addition of the xy table.
            #811256
            Clive Brown 1
              @clivebrown1
              In addition, the Universal has a screwed spindle nose to enable holding of collets, an important feature completely lacking in the drill version. It also has a fine downfeed. I think that you will find a Universal hard to come by, especially within your budget.
              #811258
              Diogenes
                @diogenes
                I think it depends more on which spindle was fitted – those with a Jacobs Taper aren’t suitable for milling work.
                #811260
                jacobsmess
                  @jacobsmess
                  Thanks. There is actually a Universal for sale on Ebay at the moment although photos don’t show if it’s a screw spindle nose clearly. It’s also 3 phase but this could easily be overcome.
                  #811261
                  jacobsmess
                    @jacobsmess
                    There’s actually a few Fobco universals on marketplace and a “seven 8” also that are within budget.
                    Would these be a better machine than the clarke?
                    #811264
                    Clive Brown 1
                      @clivebrown1
                      If it’s the one I’m seeing it also lacks the x-y table and the fine downfeed gearbox, so its milling capabilities are severely limited, it’s effectively a drill only, and a bit battered at that.
                      PS; there’s a separate Fobco table listed elsewhere at a starting price of £542, but an Asian one might do and would be cheaper.
                      #811266
                      jacobsmess
                        @jacobsmess
                        Thanks for the continued response. I think I’ll grab the clarke then. Seeing as it’s setup for milling already and has a bit of tooling with it.
                        #811296
                        Diogenes
                          @diogenes
                          The ‘family’ that the Clarke belongs to are useful & able mills if you are on a budget – I’m very content with my mine, haven’t found any compelling reason to replace it with anything ‘better’ yet.
                          #811300
                          jacobsmess
                            @jacobsmess
                            Brilliant thanks. Is it the cmd 1225 you have?
                            #811320
                            Diogenes
                              @diogenes
                              No, a Warco Major – it’s a little larger, but same general layout and mechanics.
                              If you want to search for more info and spec. for the CMD1225, large numbers were sold under other designations that included both ‘RF25’ and ‘ZX25’.
                              #811353
                              howardb
                                @howardb
                                There is an Axminster ZX25 M on ebay – dirty rusty neglected.
                                Only £200 location Telford.
                                Ebay nr 267356660251
                                Do you feel lucky?
                                #811355
                                jacobsmess
                                  @jacobsmess
                                  Thanks, seems the Axminster zx25 is heavier than the clarke 1225 which seems to be a plus. I’ll keep an eye on it though thanks
