mt4.5
mt4.5
Home › Forums › General Questions › mt4.5
Viewing 3 posts - 1 through 3 (of 3 total)
  • #795364
    Matt Smith
      @mattsmith88420
      Hi there,
      Do any of the forum members know of a supplier of the 4.5mt to 3mt spindle adapter sleeves? I noticed some older posts on the subject, are these still available?
      Matt.
      #795395
      halfnut
        @halfnut
        You don’t see them much anymore. Not that hard to make though. Match the topslide to your lathe spindle taper with a DTI and turn the OD.
        Then install it in the spindle taper and drill and bore the 3MT in situ.
        Mild steel should be good enough for home use.
        #795409
        DC31k
          @dc31k
          The ones that were around previously were commissioned by someone with a Harrison lathe. You will find further discussion on the Harrison group at groups.io
          A 4.5 to 3 adaptor is available from Grizzly in the US as a spare part for one of their lathes. They do not ship overseas, but if you have a contact in the US, that is an option.
          https://www.grizzly.com/parts/grizzly-spindle-sleeve-mt-4.5-mt-3/p97302912
          The smart money would buy a 5 to 3 adaptor, dial in a male 3MT in a four jaw and then cut only the external 4.5 MT. Less and easier work than trying to cut an internal 3MT.
