R8
R8
  • #93183
    Packmule
      @packmule
      Looking at buying a new mill with R8 fitting. Can I use my er25 collets in it ?
      #6207
      Packmule
        @packmule
        #93185
        Weldsol
          @weldsol
          Can't see any reason why not providing you have ER25 collet chuck with an R8 tail
          Paul
          #93204
          KWIL
            @kwil
            Not a problem, I use the ER25 on my Bridgeport
            #93208
            John Haine
              @johnhaine32865
              But R8 collets much better….
              #93284
              bricky
                @bricky
                I use a 2 morse taper ER25 collet chuck as well as a clair autolock with the same taper in an R8 by using anR8 2mt sleeve .The drawbar perhaps has a different thread mine is smaller so it passes through the adapter and pulls everything together.If the draw bar will not pass through turn out the threaded portion of the R8 adapter.
                Francis
                #93314
                Packmule
                  @packmule
                  Thanks for all the replys,
                  It was basically just athought as to wetherI could make more use of the collets I have (bought a full set for the lathe) but as John says If I'm losing a couple of inches then looks like bite the bullet time.
                  Just didn't want to end up with a set for this and a set for that.
                  Thanks agin
                  Bob
                  #93315
                  KWIL
                    @kwil
                    Just one other thing, R8 collets (yes I have some) are dead size, where as the ER Series are usable over a range, but then I am not limited with a restricted daylight height table to quill!
