What motor should i use?
Home Forums Beginners questions What motor should i use?
  • #64406
    nic
      @nic
      Hi there, i own a Sieg SC2 and on my list of modifications is to power the lead screw with a variable speed motor of some sort, i know nothing about motors and electronics so any advice would be much appreciated,
      many thanks in advance
      nic
      #5412
      nic
        @nic
        #64408
        Michael Cox 1
          @michaelcox1
          Hi Nic,
          I have fitted a leadscrew motor to my minilathe. You can find more details here:
          I hope this helps
          #64438
          James fortin
            @jamesfortin46829
            hi
            i am trying to build a variable power feed for my lathe and mill. i chose to use an ordinary motor as stepper motors need controllers. i managed to knock up a pulse width modulation speed controller fairly quickly.make your own pwm controller
            the trouble im having is finding a motor with enough torque at low speeds(without excessive gearing) and enough of a speed range to get a range of feeds easily.
            another alternative is gutting an old cordless drill for the speed control and planetary gearbox.
            james
