Hello all, im Mark a newly 60 retired mech engineer. Havent used a lathe since the 70s until this last year with my new little myford, now possess a pillar drill too, internal garages are not the best workspaces but its all i have. Just finished restoring a Montesa 348 (1976) and quite fancy a go at a small engine of some description. Any suggestions glady accepted, ive looked at a few kits and to be honest im no nearer a decision.. cheers Mark
Hello Mark and welcome. What kind of small engine do you have in mind? steam, internal combustion, etc and do you want to use casting or bar stock. Either way there are plenty to choose from.
Welcome, Mark, this hobby has the downside of becoming addictive, you'll be thinking of a mill next. I have ridden a Montessa 250, but had a Beamish Suzuki 250 with the Whitehawk frame. There's no way I could manage a trials bike now due to arthritis.
Im thinking internal combustion although hot air engines look interesting, steam would be great but i presume the boiler is expensive regarding testing etc so thats ruled out for now. Having no milling set-up may need to change i think but for now im still so clueless as to which way to go. Mark
PS – have seen some model plane/boat engines, but have no idea how glow engines run or what you need. So might need to investigate those too!
Hello Mark, welcome. Like you my workshop is an internal garage. It's not perfect but has the advantage for me of not having to go outside to get to it. Probably the biggest downside is no windows but its good for security.
