New Member: Tom, Kent
  • #349836
    Thomas Dye
      @thomasdye26707
      New member. Looking to eventually acquire a lathe and/or milling machine, when I accumulate the budget, that is.
      #40304
      Thomas Dye
        @thomasdye26707
        #349848
          Welcome to the forum Thomas,
          What sort of projects do you have in mind?
          Thomas Dye
            @thomasdye26707
            Hi Neil,
            My current projects are: a reflow soldering oven; a CNC router controller; and a SCARA based pick and place robot for electronic components.
            If I had metalwork tools I would use them to make more tools!
            #349863
            Mick Henshall
              @mickhenshall99321
              There are some very knowledgible (have I spelt that right 🤔 )people on here I have been helped a number of times and have been very grateful
              Mick
              #349866
              Thomas Dye
                @thomasdye26707
                This is the start of my 3D printed SCARA. For a sense of scale the dark bit is a NEMA17 stepper motor.
                Edited By Thomas Dye on 11/04/2018 20:42:31
                #350073
                george Aldous
                  @georgealdous13656
                  welcome Tom I'm in dover.
                  George.
                  #350093
                    Looks interesting Tom, what printer are you using?
                    We have a 3D printer topic (we aren't as old fashioned as you might thinkl!)
                    Thomas Dye
                      @thomasdye26707
                      Hi Neil,
                      I will be using my anet a8, it’s a prusa i3 clone with an aluminium backed heated bed and z leadscrews.
                      #350099
                      Thomas Dye
                        @thomasdye26707
                        In my SCARA each arm is over 200mm long so, to get better positional resolution I decided to use an 18:1 worm drive to reduce the whole step angular resolution to 0.1?. Obviously I have no idea whether the design will actually work, nor whether backlash will overwhelm the designed angular resolution. But, I wanted to check if anyone thought that the speed of the arm would be sufficient even with the 18x reduction.
                        #350107
                          I've no experience of implementing SCARA, but Joseph Noci is building a morgan style 3D printer and documenting it in another thread here which may have some issues in common?
                          N.
