Gauge 1 “Dee”
Gauge 1 “Dee”
Home Forums Drawing Errors and Corrections Gauge 1 “Dee”
Viewing 3 posts - 1 through 3 (of 3 total)
  • #285002
    david john
      @davidjohn66754
      On attempting to set the valve timing I found that I could not get the port openings to coincide with either the top or bottom dead centre crank positions. In fact in all cases everything seemed to be 180degrees out. The positions of the eccentrics which impart movement to the valves are governed by pins fixed to the crank webs. I have checked all the components i.e. eccentrics, crankshaft ,positions of journals and pins according to the drawing as well as dimensions and orientation and nothing seems to be amiss. I can solve the problem by moving the pins but it means fabricating another crankshaft. I would be grateful for comments as to whether I have missed something or whether the drawing is wrong.
      #38809
      david john
        @davidjohn66754
        valve timing
        #285039
        J Hancock
          @jhancock95746
          The G1MRA yahoo forum site is probably the best place to get feedback on Dee.
          I'm afraid the inside split eccentrics ' did it' for me !
