Concrete Garages, Shelving and Catastrophe
Home › Forums › The Tea Room › Concrete Garages, Shelving and Catastrophe
  • #35948
    Iain Downs
      @iaindowns78295
      To put back what came down…
      #480349
      Iain Downs
        @iaindowns78295
        I have a standard modern prefab concrete garage as my workshop.
        To date, I've been hanging things up with no more nails, in this case some vertical battens (3) with 180cm high Spur shelving. However, this came a cropper this weekend when the shelving at carrying most of my milling tools fell down. I wasn't quite underneath it.
        Interestingly, the no more nails had stuck to the concrete (I'd de-painted it) but released the wood. It had held up for around 6 months, so I was feeling quite safe!
        I decided that this needed to go back up with more security and decided to use rawlplugs.
        I managed to get one 6mm hole in the ribs about 30mm deep, but another 3 have foiled me cutting no more than about half a centimetre. This with a 750W mains hammer drill rather than my normal cordless (which probably wouldn't scratch this).
        Some googling indicates that a SDS drill is my best bet, but that's by no means certain. It seems possible that there some rebar in there and not all SDS bits will bite. I'm also not keen to spend at least 50 quid on a drill that I will use once.
        So I'm thinking of trying the same trick again, but with two additions. First, to cut some grooves of some kind in the wood battens to provide more for the no-more-nails to key on to. I would also consider a better no more nails than B&Q's best.
        Secondly and more importantly, the spur actually reaches up to the wooden frame for the roof (4×4 by the look of it) and last time I glued some battens to the frame and screwed the spur to the battens. This time I would screw through to the frame which would then take much of the force.
        I would appreciate any experience or suggestions. I have no desire for half a hundredweight of metal to fall on my head whilst I'm calmly milling away!
        Many thanks in advance.
        Iain
        #480352
        Steviegtr
          @steviegtr
          In my dads garage way back he just used the bolts that hold the garage panels together to fix angle brackets to. Then mounted these to his shelving. His were the 2 foot wide concrete panels, which are bolted together by something like 6mm bolts, panel to panel. The edges of those panels do have steel in them.
          Steve.
          #480353
          Ady1
            @ady1
            alternatively
            I jammed / braced the top of my shelves along the roof space with wooden beams
            You can get shelving from ebay
            No "fixing to the walls" required
            God knows how much weight they all have now, its a lot
            GL
            Edited By Ady1 on 16/06/2020 22:05:30
            #480355
            Chris Evans 6
              @chrisevans6
              If you where near me I would let you use my SDS. Maybe a local forum member has one ? Could you drill through and put a metal plate (big washer ) on the outside to spread the load ?
              #480356
              Steviegtr
                @steviegtr
                Posted by Chris Evans 6 on 16/06/2020 22:03:08:
                Not a good idea drilling right through a pre cast garage wall. The drill bit explodes out the back & you end up with a crator. I assume it is a pebbledash affair.
                Steve.
                #480358
                DMB
                  @dmb
                  Hi Iain,
                  Why not use free standing shelving? Similar to Dexion which is no longer made. I have seen adverts for that type where the advertiser boasts about how strong it is and quotes max. weight. Not cheap but do you want to risk being flat packed? Concrete garages have internal strengthening as you found out and I wouldn't have considered drilling it. What about insulating, walls, roof? I think you could suffer serious rusting of machinery and steel stocks. Have a look back on past postings on this.
                    Dunno what you mean by ‘standard’. Nor do you give any indication of the dimensions of your shelving. All useful information to make sensible suggestions.
                    Mine is over 25 years old and vertical panels are bolted together. I would either drill between the panels and secure from the outside or replace horizontal bolts with longer items and fit decent battens to those longer fixings.
                    I don’t like ‘no nails’ glue for that application. It is good for some things but, IMO, not all scenarios.
                    My garage has 100mm of celotex insulation against the panels, so not a choice for me. I put substantial uprigts from the floor to support any shelving at both the wall and outboard edge of shelves.
                    #480366
                    Cornish Jack
                      @cornishjack
                      I had a near replica of Iain's 'collapse only mine was 'Rawlplugged' in to the walls. Thankfully mine happened while I was absent, so just the mess to clear up!.
                      My remedy was as DMB suggests, Dexion frames, free standing for weight bearing but wall fixed for added stability, if that makes sense? No further traumas (fingers crossed!)
                      rgds
                      Bill
                      #480372
                      Ady1
                        @ady1
                        We recently had a bathroom wall removed and it was basically cardboard egg carton with a skim of plasterboard
                        3 hammer blows could smash right through from one room to the next, it's pathetic
                        Yet there is a huge wall cupboard full of tins and dishes hanging from this piece of garbage wall in the kitchen which must weigh 100 kilos plus for the last 10 years
                        The way they did it was the obvious screw it to the battens bit but that's nowhere near enough for the weight being carried here, the internal verticals are like 3×3
                        The sneaky bit was the kitchen tiles, they are about an inch thick and support the bottom of the cupboard along the wall and transfer most of the weight down towards the floor
                        The other flats at my bit (3 of us) only have corner cupboards to the ceiling
                        Edited By Ady1 on 16/06/2020 23:26:01
                        #480374
                        Alan Waddington 2
                          @alanwaddington2
                          I use my mothers prefab concrete garage as an extra store.
                          Made some racking from hollow section
                          legs sit on floor, tops are bolted to roof joists
                          Reckon there must be going on for 1/2 tonne of steel sat on them with no issues.
                          Could easily be adapted for sheves, just by adding wood
                          #480386
                            When drilling holes in concrete I have found there are carbide masonry bits and there are carbide masonry bits. The pricier good brand-name ones will drill into hard concrete and seem to cope with rebar ok where the cheap hardware store junk masonry bits do what you have described: one good hole then lose their edge and grind away without going anywhere much. Brand I use here are IRWIN but no idea if they are available where you live. But basically you get what you pay for.
                            For heavy shelving I'd use the metal expanding bolts, not the plastic plug types.
                            #480387
                            Paul Lousick
                              @paullousick59116
                              Use a hammer drill when drilling concrete. Heaps easier to drill a hole. Drill a pilot hole first for large holes and as stated above, use expanding metal bolts not the plastic plugs if holding anything heavy.
                              Paul.
                              #480391
                              clogs
                                @clogs
                                Hopper,
                                Irwin brand is available in the North of the planet……
                                wasn't that Stanley……..?
                                mostley here tho u seem to find Bosch or Dewalt…..
                                Lucky ol me,I have 4 Hilti SDS's……diff sizes for diff jobs…..
                                for evil jobs always buy a new Hilti drill bit….these will punch there way thru rebar ……..
                                Had to drill a hole into a concrete Wine Vat in France for a friend…man that was tough…never seen concrete like that befor…….hahaha
                                #480399
                                Sam Longley 1
                                  @samlongley1
                                  I have fully lined my concrete garage & in doing so have made lots of fixing points. I obtained some 25*50 *2.400 battens & some binding wire. I have some 8 inch steel fixers nips to twist the wire. I replaced the bolts to the joints in the concrete panels with lengths of stainless studding such that the ends stuck out 25mm both sides. This gave an anchorage point for the wire. One could do it by just slackening the bolts & working the wire behind them, but I have lots of studding left from a job so i just swopped it.
                                  I placed the battens up the face of each joint. I passed the wire from one end of the studding round the face of the vertical batten back to the other end of the studding & twisted it really tight. I cannot recall if I did 3 or 4 per length This holds the batten really tight. The wire started to cut into the batten.
                                  This then allowed me to place 25 mm celotex between battens,& face the lot with 4mm ply, up to 6ft high ( 1.5 sheets of ply wide)
                                  However, back to your point. I can now screw things like my shelving (which is still supported at the front down to the floor) to the battens which are at 600mm centres round the garage.
                                  Edited By Sam Longley 1 on 17/06/2020 07:53:31
                                  #480426
                                  larry phelan 1
                                    @larryphelan1
                                    Would never depend on any sticky stuff to hold up shelves of any kind !
                                    Hilti leads the way !!
                                    #480431
                                      When I dry-lined my workshop into an ancient cast garage, I started with a brand new Woolworths rechargeable hammer drill. Amazingly it survived but I got through truckloads of carbide tipped masonary bits, usually melting out the brazed in tips.
                                      I'm sure that the endless sessions swapping hands to force the bits in were the origin of issues with both arthritis and carpal tunnel issues taht showed up a few years later.
                                      Lucky I didn't get vibration white finger too.
                                      Watford
                                        @watford
                                        Never mind about you, what happened to the precious tooling??? face 5
                                        #480438
                                        Oven Man
                                          @ovenman
                                          According to my neighbour across the road drilling holes on a new concrete prefab garage will void any warranty.
                                          Peter
                                          #480440
                                          Circlip
                                            @circlip
                                            Made hangers that go over the top edge thickness (Like the ones the roof bars use) with a packer at the bottom to ensure they sit vertical. Was advised by Garage fitters NOT to drill into concrete walls as it could burst the panel. There is a difference in the concrete used for garage panels. There is a reason any holes for fixings are cast in at manufacture.
                                            Regards Ian.
                                            #480467
                                            Roger Whiteley
                                              @rogerwhiteley62172
                                              I bought some heavy duty shelving from Amazon (sorry), because we could get nothing else within a radius of 50 miles. But I'd want stuff fixed to the wall, *somehow*, if only to stop it tipping forwards.
                                              I've had a sort-of-workshop in a cast concrete garage, about 60 odd years old, horrible stuff and yeah its got rebar in. I'd line it, for two reasons: 1. to provide space for insulation which is good for the condensation problem and 2. To provide something to fasten stuff to, which brings me to my present workspace..   I'd use 83×36 CLS at 600 centres, made just like a stud wall.
                                              My current sort-of-workshop is a grounded refrigerated van body thick plastic lined, takes woodscrews a treat, even without a pilot hole.
                                              But my reason for posting is that I've discovered the joys of French Cleats for hanging stuff from, a length of 2×1, OK 18×44 PSE, with a 20 degree corner sawn off, with screws every 150mm fastened horizontally to the wall will support practically anything – even those kitchen cupboards… It took me ten minutes to rip the corners off three 2m long strips with a Lidl cordless circular saw. And about the same time to attach to the wall and to the shelves I wanted to hang off them. When I move, I can leave the strips on the wall and just make some more, at heights that work for me in the next workspace. *sigh, nightmare*
                                              Edited By Roger Whiteley on 17/06/2020 12:12:26
                                              #480479
                                              Sam Longley 1
                                                @samlongley1
                                                Bison Concrete produced over a million concrete garages for local authorities & stopped making them circa early 80's. When they stopped production at Chadwell, They sold the moulds, for peanuts, to Thurrock Concrete Ltd. who rented part of my builders yard. They then made spare parts for damaged Bison garages for LAs, which was a clever move as it was cheaper than replacing a full garage.
                                                They did not use rebar as such but prestressed the sections with 1/4 inch diameter HT steel "wire". the pre stressing operation was quite technical & the one operation that the owner himself always insisted on doing. A broken overstressed wire, or errant anchor collet, could fly out many yards like an arrow. with serious consequences.
                                                They always advised customers NOT to cut any pre stressing wires because, although they were held in set concrete they could pull back a little causing pieces of concrete to shatter outwards. Drilling a concrete panel can sometimes result in a long crack along the line of the wire, resulting in erosion of the wire at some later date.
                                                I imagine that modern garages are made using the same method
                                                Edited By Sam Longley 1 on 17/06/2020 13:45:37
                                                #480480
                                                Lee Rogers
                                                  @leerogers95060
                                                  aluminiumwarehouse.co.uk I have used thier easyfix system of square tube to make racking , a cold frame and shelves. Adding a strategic riveted plate on some corners can be done for a bit of extra rigidity but not always needed.
                                                  #480482
                                                  ega
                                                    @ega
                                                    Sam Longley 1:
                                                    Your post about Bison was very interesting to me. I owned a couple of these many years ago and installed a bench across the end of one supported on timbers bolted through the concrete panels. It seems that I was lucky not to have any problems of the kind you describe.
                                                    IIRC, these garages were normally available as singles but they could be lengthened by the addition of the modular panels which meant that there could be room for a small car and a modest workspace.
                                                    #480483
                                                      Posted by Circlip on 17/06/2020 10:21:50:
                                                      Regards Ian.
                                                      The reason for holes being positioned at manufacture is simply to avoid the erector having to do more than bolt things together and ensure those necessary holes line up! Concrete has good compressive strength but poor in tension – either when drilling thin unsupported sections or affixing things to them.
                                                      If parts do not line up, wedges or spacers (shims) are fitted wherever needed. The centre area of panels are much thinner to keep weight (and cost) down, which is why I said I would fix between the vertical joints, from the outside.
                                                      All the concrete sections of my garage were pre-tensioned with reinforcing wires, not larger diameter rebar.
                                                      IIRC, as visitors, we were not allowed near the pre-tensioned moulds when on site at the local precast concrete works – these were wires stretched over a distance of about 100-150m for railway ‘sleepers’ with several hundred tonnes of tensioning force applied over that length of moulds. Concrete was the usual 40N/mm^2 mix. I expect the sections of my garage are of similar compressive strength.
                                                      Structures with smaller panels, fitted between slotted uprights, would have been made like paving slabs – simpler (possibly unreinforced) pressed moulding methods. Those types should definitely not be drilled – either into, or through!
                                                      Edited By not done it yet on 17/06/2020 14:10:01
