End Mill Sharpening of Helical Flutes
Home Forums Help and Assistance! (Offered or Wanted) End Mill Sharpening of Helical Flutes
  • #423903
    Tony Worrall 1
      @tonyworrall1
      I have found a way to sharpen the helical flutes of End Mills and Slot Drills using a Dremel grinder attached to my Mini Millert plus a few gizzmos I made.
      If anyone wants info and or photos I can supply but the photos are more or less self explanatory.
      Tony
      #33437
      Tony Worrall 1
        @tonyworrall1
        Sharpen End Mills using Small Milling Machine
        #423905
        Andy Carruthers
          @andycarruthers33275
          I am interested Tony…
          #423908
          Tony Worrall 1
            @tonyworrall1
            Hello Andy
            Thank you for your interest.
            I have only just joined this forum and still a bit green as to how it works.
            I have tried to create an Album of photos associated with my membership. The photos attempt to show how I achieved the sharpening procedure.
            If you need further explanation you can ring me on ****************** (Edit by PM)
            Tony
            Edited By JasonB on 13/08/2019 13:49:35
            #423909
            AdrianR
              @adrianr18614
              Hi Tony,
              Unless that is a throw away phone or you like scammers etc. I would not publish it's number on the internet.
              Either delete the post or ask Neil or one of the other moderators to delete it. You can send private messages to members using Message Member under their post.
              If you have added the photos to an album you can insert them into posts using the camera icon on the edit box. They will then be shown inline in the post.
              I just looked at all your pictures, looks like a good idea, could be a perfect use for the worn out old ML2 I inherited. I wonder if it would be possible to do the side flutes on the lathe too. Mount the cutter between centres, Fix the finger to the cross slide, dremel to top slide, then move the saddle to grind the flute.
              Adrian
              Edited By AdrianR on 13/08/2019 13:03:28
              #423912
              Tony Worrall 1
                @tonyworrall1
                Hello Adrian
                Thank you for info ref phone number.
                I am having trouble finding a way to delete it or how to contact a moderator
                Please help if you can
                Tony
                #423917
                peak4
                  @peak4
                  Posted by Tony Worrall 1 on 13/08/2019 13:08:23:
                  Hello Adrian
                  Tony
                  Hello and welcome, just reported it to admin for you, using the little flag icon at bottom right of your post.
                  For future reference, the way this forum works, it  is that one can only edit a post for a short period of time; it's not ideal but mods are friendly and helpful on here.
                  Bill
                  Edited By peak4 on 13/08/2019 13:23:29
                  #423927
                  Tony Worrall 1
                    @tonyworrall1
                    Hello Bill
                    Thanks so much for your help – thats great.
                    Sorry to be a nuisance.
                    Tony
                    #423932
                      Done
                      #424179
                        How to post album pictures here:
                        http://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=4
                        Posted by peak4 on 13/08/2019 13:22:34:
                        Brown envelope in the post…
