Myford chuck ‘oiling point’
Home Forums Help and Assistance! (Offered or Wanted) Myford chuck ‘oiling point’
  • #33144
    JimmieS
      @jimmies
      #338120
      JimmieS
        @jimmies
        Have just come across a 'lost' Myford branded 4" three jaw chuck (Toolmex made in Poland) which I had totally forgotten about. There is what would appear to be an oiling point – recess with ball in centre on the front face. Am I correct and if so what grade/ type of oil should be used?
        Any one able to give a price guide as, after doing without I probably do not need it. It is complete with key, seem to have had little use and is undamaged save for some very light surface rust acquired in 'storage'. The jaws move smoothly.
        #338121
        David Standing 1
          @davidstanding1
          Price guide? A photograph would help.
          #338125
          JimmieS
            @jimmies
            True. Will try tomorrow night.
            Jim
            #338130
              Same as you use for the slideways will be fine.
              #338145
              JohnF
                @johnf59703
                JimmieS you might find this interesting its a previous post on this forum, regarding oil I would use a thicker oil that will be retained better when the chuck is in use. I have some Shell Toner R — no longer available in the same grade, it is very "sticky" as a matter of interest I have seen it suggested that chain saw chain oil is good for this application as well as change wheel lubrication – same reasons.
                Ed Dinning 1
                  @eddinning1
                  Hi Gents, I have with success used PTFE spray as it is non sticky so no swarf pick up and it leaves a very fine film.
                  Ed
                  #338161
                  roy entwistle
                    @royentwistle24699
                    Ed How are you going to spray through an oiling point with ball bearing in the middle? ( see original post )
                    Roy thinking
                    #338162
                    Sub Mandrel
                      @submandrel
                      The oil needs to be fluid enough to spread through the chuck from the oiling point.
                      #338165
                        Oi! Mandrel, who rattled your cage?
                        N.
                        #338166
                        Bill Davies 2
                          @billdavies2
                          Out of hibernation?
                          Bill
                          #338199
                          Robbo
                            @robbo
                            When you've given the chuck a few squirts with the oil gun, put it n the lathe and give it a spin to throw out surplus oil.
                            Being prepared with a cloth held in front of the chuck will save your shirt front from unwanted lubrication.frown
                            #338202
                            David Standing 1
                              @davidstanding1
                              Posted by Neil Wyatt on 25/01/2018 10:09:38:
                              N.
                              The voices in your head are talking to each other in public!
                              Scary…….cheeky
                              #338215
                              NJH
                                @njh
                                I fear these could be symptoms of D.I.D – I’ll leave it to you to look up. If this is not the case maybe there ARE two of you and both are contributing to ME discussion -either way maybe a case for a wage increase ?
                                Norman
                                #338311
                                Ed Dinning 1
                                  @eddinning1
                                  Hi Gents, should have made it clearer, PTFE spray works best is chuck is stripped, but works pretty well if the jaws are simply wound out to expose the scroll.
                                  Ed
                                  #338370
                                  JimmieS
                                    @jimmies
                                    #338376
                                    David Standing 1
                                      @davidstanding1
                                      It looks in nice unabused condition.
                                      Doog has an almost identical one on eBay at the moment at £75…..but no bids and it finishes in two days.
                                      Supply and demand – there's plenty of them around, so it's a buyers market.
                                      Value probably in the £60-£80 range.
                                      I would whip the jaws out and give it a good clean first, start at £80 and drop it £5 to £10 every time you have to relist it!
                                      #338439
                                      JimmieS
                                        @jimmies
                                        David, many thanks for you advice. Much appreciated.
                                        Jim
                                        #338447
                                        peak4
                                          @peak4
                                          Posted by Robbo on 25/01/2018 14:38:38:
                                          Hmm, I'm not a trained engineer, well not mechanical anyway, but I'd suggest a soft paper towel, rather than a cloth if it's going near any moving bits like spinning chucks.
                                          Bill
                                          #338454
                                          Chris Trice
                                            @christrice43267
                                            I might be worth that if it has both sets of jaws.
