Headstock – Performance of the gears
Home › Forums › General Questions › Headstock – Performance of the gears
  • #578133
    Franco Convertini
      @francoconvertini28916
      Is there anyone who can help me reduce the play of these gears on the head shaft? Thank you in advance for the time you will want to dedicate to me
      VIdeo
      Edited By Franco Convertini on 02/01/2022 17:43:19
      #28497
      Franco Convertini
        #578135
        Martin Connelly
          @martinconnelly55370
          #578159
          bernard towers
            @bernardtowers37738
            If it’s a S7 it’s not gear play but the locking mechanism for direct drive. Mine has some play, the same amount for the last 30years but makes no noise. Just a thought if it had no room in it it would be difficult to operate
            #578171
            Franco Convertini
              Yes, it's an S7, and that's the locking mechanism for direct drive.
              Do you think it's okay?
              #578172
              Franco Convertini
                #578177
                ega
                  @ega
                  I watched and listened to the video and assume that the audio/noise is irrelevant to the question.
                  I, too, have some movement between the backgear and the pulley assembly when the backgear key is engaged. As with bernard towers' machine this has been the case for many years and so far as I know has never been a problem.
                  I would think that the only way to reduce this backlash would be to replace one or more components. Your bronze gear appears, perhaps, to be rather worn but this is a different matter.
                  Edited By ega on 02/01/2022 23:17:47
                  #578193
                  Franco Convertini
                    Thanks for the answers, now I'm calmer. Before, I was afraid that something might break.
                    Here in Italy, in the area where I live, it is difficult to find spare parts.
                    Greetings, Franco
