Rudder Bushes on Boat
Home Forums General Questions Rudder Bushes on Boat
  • #409292
    Daniel
      @daniel
      Hi everyone,
      I need to make two rudder bushes for a sailing boat.
      The old ones look like nylon, but I'm assured it isn't.
      Apparently nylon isn't suitable for marine use.
      Does anyone know what material it would be.
      Many thanks for any help.
      Daniel
      #26606
      Daniel
        @daniel
        #409295
        Frank Gorse
          @frankgorse
          Delrin,or acetal which is similar but not the same,has far less water absorption/swelling problems than nylon and has long been used for such things. Or try UHMWPE,even less absorbent and the frictional properties of teflon but slightly more trouble to machine than delrin.
          Direct Plastics’ website has lots of info and they give a good service-usual disclaimer.
          #409304
          Sam Longley 1
            @samlongley1
            Before beginning to make rudder bearings it may be worth looking on this site. Jefa make roller bearings for a wide range of craft & by the time one has invested in the material one could have bought a ready made bearing
            But in any event do NOT use nylon. I use tufnol in my rope cutter bearings, but in rod form, can be very expensive– depending on diameter, of course
            Edited By Sam Longley 1 on 15/05/2019 07:25:32
            #409336
            Paul Kemp
              @paulkemp46892
              Thorplas from Thorndon plastics is an established marine bearing material, the blue grade will be fine, it's available in cored rod form so not too much waste. Quite expensive though if I recollect correctly. As already said nylon is no good as it absorbs water and will swell, which will mean your rudder stock will be well and truly stuck!
              Paul.
              #409348
              Clive Hartland
                @clivehartland94829
                Boil the Nylon and let cool and it will not absorb any more water.
                #409358
                Philip Rowe
                  @philiprowe13116
                  Posted by Clive Hartland on 15/05/2019 14:39:49:
                  First time I've ever heard that. I've always understood nylon is hygroscopic, end of story. But no doubt someone will be along soon to prove/disprove.
                  Phil
                  #409360
                  vintage engineer
                    @vintageengineer
                    Why not use PTFE?
                    #409371
                      Posted by Philip Rowe on 15/05/2019 16:34:58:
                      Phil
                      I think Clive's approach fills it up with water, so if you machine it before it dries it might go loose but it won't swell up.
                      #409378
                      Clive Hartland
                        @clivehartland94829
                        OK, the supply of surveying staves was from Australia. We sold them on and then the complaints came in that they were sticking as the stave guides were Nylon. Complaint to Surmac in Aussie. set them off to find a cure.
                        The cure was to boil the Nylon. They then sent us boxes of sliders that had been treated and we replaced them as soon as they came in, If I recall we never had another complaint.
                        #409380
                        Clive Hartland
                          @clivehartland94829
                          Neill, no, the item was hot formed in a press and then boiled.
                          #409579
                          Craig Smith 3
                            @craigsmith3
                            Hi Daniel,
                            Can you tell me what size is your sailing boat? Dinghy, Trailer Sailer or bigger?
                            I am a boatbuilder by trade and rigging boats ready to go sailing was my business for many years. I think most of the materials the other guys suggested will do the job and yes Nylon tends to cause issues. Might be able to minimise the issues using Clive’s suggestion, I don't know, but with other stuff readily available and easier to machine, I would go for something else.
                            Frank is correct, rudder bearings are quite often made from Acetal or Delrin, which is the trade name of one of the common forms of Acetal. It is easy to machine and is hard enough that it can be polished up if required.
                            Depending on the size required, it might just be faster and easier to by some off the shelf as suggested.
                            Craig.
                            #409598
                            Circlip
                              @circlip
                              Some nylons are hygroscopic and yes, boiling in hot water does work. Was given this tip when freshly molded nylon components were found to be brittle. Water absorbed made them flexible.
                              Material was Nylon 6. Nylon 66 was designed to be less absorbent.
                              +1 for Delrin or Acetal.
                              Regards Ian.
                              #409634
                              Ian S C
                                @iansc
                                I think I used Delrin for the bushes on the rudders of my brother in law's 16 m/ 12 tonne catamaran. Built to Safe Ship Management survey standards, steering is hydraulic. Folie a Deux is a twin 150hp Volvo powered ocean cruising boat now based in Australia. The rudders did have a problem on the voyage from NZ to Fiji, over use of the steering caused the hydraulic fluid to over heat, so the sensitivity of the steering (electronically controlled with a Navman G pilot 3100 autopilot), I don't think it was tight bushes that put a load on the steering as the manual steering was quite free.
                                #409742
                                Daniel
                                  @daniel
                                  Thank's to everyone for the input. Looks like Delrin is the favoured option.
                                  Craig – It's a Westerly something. I'll see if I can find a photo.
                                  I agree that it probably would be easier to simply buy them. But, it's my father's boat, and
                                  he's decided that I can make them for him. crook
                                  Her's a photo of the old ones …
                                  Thank's again, everyone, for the interest.
                                  ATB, Daniel
                                  #409756
                                  Frank Gorse
                                    @frankgorse
                                    Do have a look at Ultra High Molecular Weight Polyethylene. I used it for a job on our ‘Westerly Something’. It’s even less affected by moisture than delrin,has similar frictional properties to ptfe and is very hard wearing. It’s also quite cheap.
                                    #409836
                                    Craig Smith 3
                                      @craigsmith3
                                      Hi Daniele,
                                      Like always, a picture says it all. I wondered if you were talking about small bearing inserts like in a dinghy rudder gudgeon or as your picture shows, larger bushing for the rudder shaft. You did say bushes, but best to check.
                                      Hard to be certain, but the way the break has happened it looks like a form of Acetal. Delrin/Acetal tends to be quite hard and boney , if that is even a word (like bone), so it breaks cleaner than a lot of other plastics, which stretch and deform before they and break.
                                      Frank has mentioned it a couple of times and I think he is spot on. UHMWPE (you can see why they use the acronym) is a great alternative. Doesn’t machine as cleanly as Delrin, but it machines well enough. It’s has good dimensional stability in moisture and great resistance to abrasion. And like Frank says, CHEAPER, especially as you have to buy some quite large diameter solid rod.
                                      I used it a bit in the past and I remember one time in particular I used it as end plugs in a spinnaker pole. I made them a neat fit and even after five years in and out of water and UV, the plugs never swelled and always slid in and out without issue.
                                      Hope it goes well.
                                      Craig
                                      #409844
                                      Daniel
                                        @daniel
                                        Thank's Frank & Craig, for the suggestion.
                                        I'd already been off to the stockists. They were short on Delrin, so I bought a length of HDPE.
                                        I hope that will work.
                                        For clarity, the physical damage to the old bushes (all of it), was the result of my father's efforts in extracting them. He has since told me that the top bush had no play at all; and the bottom one had about 1/4" (6mm), side to side.
                                        disgustdont know !!!
                                        For those who may be interested; here are a couple of pics, of said boat.
                                        Thank's again for your interest and help.
                                        ATB, Daniel
                                        #409850
                                        Craig Smith 3
                                          @craigsmith3
                                          Hi Daniel
                                          Okay, you are into it. I'm sure the PE will do the job. Seeing the boat moored like that takes me back to my youth. No sailing anymore, but now I spend a lot less money as well.
                                          You mentioned about the top and bottom bearing/bushing of the rudder stock. Just keep in mind that the bottom one is the fulcrum and takes most of the load, so any slop down there is not good. If either is to be an interference fit, it should be that bottom one. The top one can handle a small amount of tolerance if needed to ease things up.
                                          Once made, let us know how it went. Just as a matter of interest, where is the boat moored in that photo?
                                          Craig.
                                          #409853
                                          Circlip
                                            @circlip
                                            Forgot the obvious one, Lignum Vitae.
                                            Regards Ian.
                                            #409863
                                            Daniel
                                              @daniel
                                              Posted by Circlip on 19/05/2019 09:50:57:
                                              Regards Ian.
                                              wink 2 …. I even briefly considered bronze
                                              #409864
                                              Daniel
                                                @daniel
                                                Yes Craig, another hobby that demands deep pockets.
                                                She's moored just up from the Bodinnick Ferry, at Fowey, in Cornwall.
                                                I think it's called Wiseman's Creek, or similar.
                                                I'll post up my attempts, once done.
                                                ATB, Daniel
