Do you clean up your rough end
Home › Forums › General Questions › Do you clean up your rough end
Viewing 25 posts - 1 through 25 (of 38 total)
  • #380323
    Former Member
      @formermember19781
      #26291
      Former Member
        @formermember19781
        #380324
        Thor 🇳🇴
          @thor
          Hi Bill,
          I made the same experience as you years ago so I try to clean up the sharp end of the bars before putting them back in the storage rack.
          Thor
          #380325
          Merddyn’s Dad
            @merddynsdad
            Hi Bill,
            Many years ago I got a reprimand from my manager for wasting mine and company time.
            It was my habit to deburr or chamfer the ends of all metal bars, usually steel but also brass and Lt Alloy before they were placed on the storage racks in the stores.
            So, I stopped, until later one individual gashed his hand bad enough to require hospital treatment, this was before the days of PPE.
            I had a different working relationship with the manager after that.wink
            Steve
            #380327
            Robbo
              @robbo
              Bill
              The 60 year old scar on my thumb reminds me to always clean up rough ends crying
              #380329
              Peter G. Shaw
                @peterg-shaw75338
                Yes, just to take off the sharp edges
                Peter G. Shaw
                #380332
                Mick B1
                  @mickb1
                  Not so much to avoid risk of cuts – don’t think I’ve ever cut myself that way – but to ensure a clean, true grip in the chuck, I deburr and usually chamfer the back end too.
                  #380336
                  Chris Gunn
                    @chrisgunn36534
                    Not only do I clean the burrs off, I use a white correcting pen marker and mark the ends with the size so I can find the right size easy next time.
                    Chris Gunn
                    #380344
                    Boiler Bri
                      @boilerbri
                      Your Elf n safety says all cut ends should be cleaned to prevent damage to fingers. Its a bit like a small offcut of round bar on the floor, you just dont do it.
                      46 years ago my boss boll(£;: me off for doing these things and you remember not to do it – if you dont your stupid 🤔
                      Well thats what he told me 😂
                      Bri
                      #380346
                      larry phelan 1
                        @larryphelan1
                        Only takes a moment to do it,result ? no more gashed fingers.!
                        Yes,I always clean up cut ends,the damage they can do has to be seen to be believed [been there,done that,but not any longer ! ]
                        Try it,you get used to it !
                        #380347
                        Jon Lawes
                          @jonlawes51698
                          I don't, but I will now.
                          #380348
                          Pete Rimmer
                            @peterimmer30576
                            I find that stainless can pull up a nasty burr. A quick swipe with a file gets it gone though.
                            #380349
                            ChrisH
                              @chrish
                              I bought a bench mounted belt sander – the type with a longish belt in the front usually vertical and a circular disc on the side – and mounted it on the end of the bench. Now every piece of stock I cut, and the remaining bit, gets a (very) quick dress up on the belt to take the sharp edge off, as does any stock I buy if it arrives with a sharp edge. I say 'a (very) quick dress up' because that's all it takes, literally seconds, but it drastically reduces the chance of a cut hand. So a no-brainer.
                              The bits I mill have the edges dressed with a file, as do any circular ends on lathe produced parts unless a chamfer has been put on, but I guess most folks would do that anyway as a matter of course. Saves cuts to hands!
                              I also mark each end of the bar stock with the EN number and the size to help ID it later when I have forgotten what I do have with a Sharpie, takes the guesswork out later. It helps me anyway!
                              #380352
                              Jon
                                @jon
                                Never it wastes needless time.
                                #380373
                                thaiguzzi
                                  @thaiguzzi
                                  Don't bother on alloy.
                                  But steel and S/S – chamfer or deburr before it goes back in the rack.
                                  #380377
                                  John MC
                                    @johnmc39344
                                    I don't bother, its a bit like cleaning the machine after every session, life's too short……..
                                    The nearest I've seen "industry" bothering to do this was a rough chamfering of bar stock to go in to an autofeed for a capstan.
                                    #380389
                                    Mark Rand
                                      @markrand96270
                                      I tend to go the other way, I normally use gloves when handling lengths of stock. Most of my steel stock retains the layer of cruddy oil on it from when it came from the stock holder and it is grubby stuff to handle. I also find that square and rectangular lengths of cold rolled steel can cut. So until I've band sawed off the length I want to work on and wiped it off, I tend to try to remember to keep my bare pinkies off it.
                                      #380393
                                      Ian S C
                                        @iansc
                                        You might as well do it while it's still in the lathe, you'll have to do it at the beginning of the next job, and that time might be wasted, it's going to happen some time.
                                        Ian S C
                                        #380402
                                        JOHN MOSLEY 1
                                          @johnmosley1
                                          You will find all people who did there apprenticeships' in the 60/70s do take any sharp edges of anything they touch. We did not use gloves then. I remember only too well an older engineer coming up to me and saying did you machine this, I proudly said yes. This was followed by a verbal and physical assault on me saying take the beep beep burs off next time.
                                          #380403
                                          mechman48
                                            @mechman48
                                            Posted by Ian S C on 13/11/2018 10:02:53:
                                            Ian S C
                                            +1 – I tend to face off the end & put a light chamfer on… then ready to spot / centre drill on next job.
                                            George.
                                            #380407
                                            Mark Rand
                                              @markrand96270
                                              Certainly debur or chamfer parts after machining or before if needed. But lengths of stock put back on the rack after sawing get the gloves.
                                              #380427
                                              John MC
                                                @johnmc39344
                                                So what about all the other sharp objects in the workshop?
                                                Scriber with a cork on the pointy bit?
                                                #380429
                                                David T
                                                  @davidt96864
                                                  Posted by John MC on 13/11/2018 16:32:57:
                                                  I must admit I put a rubber teat on the hook end after repeated injuries blush
                                                  #380433
                                                  Jon Lawes
                                                    @jonlawes51698
                                                    Unless you are very special you pick up tools with sharp edges by the blunt bit. Leaving sharp edges on things adds a random element which could easily be avoided.
                                                    I am trying to show my boys how to do things properly in the workshop, a few seconds here could save a trip to casualty or even just some minor inconvenience.
                                                    #380696
                                                    BOB BLACKSHAW 1
                                                      @bobblackshaw1
                                                      In the 70s we use to make a deburring tool from a part of a hacksaw blade. A small hook ground with a cutting angle and tape for the handel, worked great on sheet metal till you slipped and sliced the top of the thumb.
                                                      Deburring lengths of sheet steel you could actually get oil smoke from the tool, quite satisfying with lengths of fine swarf on the floor. Deburring all blanks was mandatory then, I bet its not today.
